Contacting HomeSeer This Week
See more
See less
system uptime script error
  • system uptime script error
    script runs as .vb but no population of q3 or q4.
    no log error from script
    /8/2006 8:50:17 AM Info Event Trigger "System Uptime"
    3/8/2006 8:50:17 AM Info Running script in background: HomeSeerUpTime.vb
    script;
    ' define q3 and q4 as status type
    ' Option Explicit
    Const bDEBUG As Boolean = False
    Const strCurUpTimeHCUC As String = "q3"
    Const strMaxUpTimeHCUC As String = "q4"
    Function stripTime (str As String) As String
    Dim strTemp As String
    strTemp = str
    If bDEBUG Then
    Call hs.WriteLog("HomeSeerUpTime", "stripTime Input: '" & strTemp & "'")
    End If
    strTemp = Replace(str, "Days ", "")
    strTemp = Replace(strTemp, "Day ", "")
    strTemp = Replace(strTemp, "Hours ", "")
    strTemp = Replace(strTemp, "Hour ", "")
    strTemp = Replace(strTemp, "Minutes ", "")
    strTemp = Replace(strTemp, "Minute ", "")
    strTemp = Replace(strTemp, "Seconds", "")
    strTemp = Replace(strTemp, "Second", "")
    strTemp = Trim(strTemp) & " "
    If bDEBUG Then
    Call hs.WriteLog("HomeSeerUpTime", "stripTime Output: '" & strTemp & "'")
    End If
    Return strTemp
    End Function
    Function timeSecs(str As String) As Integer
    Dim iDays As Integer
    Dim iHours As Integer
    Dim iMinutes As Integer
    Dim iSeconds As Integer
    If bDEBUG Then
    Call hs.WriteLog("HomeSeerUpTime:timeSecs", "str: '" & str & "'")
    End If
    iDays = Cint(Mid(str, 1, Instr(str, " ")-1))
    str = Mid(str, Instr(str, " ")+1)
    iHours = Cint(Mid(str, 1, Instr(str, " ")-1))
    If bDEBUG Then
    End If
    iMinutes = Cint(Mid(str, 1, Instr(str, " ")-1))
    If bDEBUG Then
    End If
    iSeconds = Cint(Mid(str, 1, Instr(str, " ")-1))
    timeSecs = ((iDays * 24 + iHours) * 60 + iMinutes) * 60 + iSeconds
    End Function
    Sub main (strArg As String)
    Dim strUpTime As String
    Dim iUpTimeSecs As Integer
    Dim iMaxUpTimeSecs As Integer
    Dim strMaxUpTime As String
    strUpTime = hs.SystemUpTime()
    If bDEBUG Then
    Call hs.WriteLog("HomeSeerUpTime:main", "strUpTime: '" & strUpTime & "'")
    End If
    iUpTimeSecs = timeSecs(stripTime(strUpTime))
    Call hs.SetDeviceString (strCurUpTimeHCUC, strUpTime)
    Call hs.SetDeviceLastChange (strCurUpTimeHCUC, Now)
    strMaxUpTime = hs.DeviceString (strMaxUpTimeHCUC)
    If Not Instr(Trim(Ucase(strMaxUpTime)), "UNKNOWN") And _
    strMaxUpTime <> "" Then
    iMaxUpTimeSecs = timeSecs(stripTime(strMaxUpTime))
    If bDEBUG Then
    Call hs.WriteLog("HomeSeerUpTime", "MaxUpTime: '" & iMaxUpTimeSecs.ToString & "'")
    Call hs.WriteLog("HomeSeerUpTime", "UpTime: '" & iUpTimeSecs.ToString & "'")
    End If
    If iUpTimeSecs > iMaxUpTimeSecs Then
    Call hs.SetDeviceString (strMaxUpTimeHCUC, strUpTime)
    Call hs.SetDeviceLastChange (strMaxUpTimeHCUC, Now)
    End If
    Else
    End If
    End Sub
    HS3 Standard Edition 3.0.0.258
    Error
    It does nothing here as well. I get the following error in my log:
    Running script, script run or compile error in file: HomeSeerUptime.txt1011:Expected '=' in line 3 More info: Expected '='
    I have checked to make sure that I didn't change anything, same script. Running HS 2.1.18
      Same issue here as well
      Thom
        I posted an updated version
        Sorry for the troubles... I updated the version in the script library, and added some tips. The key is to add the string "init" to the script parameter the first time it's run. After the script has run once, take the "init" out, and leave a null string ("") The two attached jpg's show what I mean. Hope this clears things up!
