Originally posted by gbdesai
Wakemeup VR Script updated for multiple users and 2.0 compatible Discussion
HS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
can't get past today or tommorow prompt
I am using the vr through the phone. pci modem. I have changed all of the hs.speaks to system.speak and everything works up to the is this for today or tommorow? I see a speakwait start in the log and my voice commands created but I cannot get it to hear me. How have other gotten by this?
Kirk,
I am not going to be able to help you here... I dont have the modem and dont use hs.phone for VR.
TobyHS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
The latest version already has the startlisten commands commented out (see 5/14 posts above)...HS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
Sorry, I don't think I was very clear in my last post. I realize that version 2.1 has system.startlistening commented out. The problem is that homeseer phone still requires that system.startlistening. I tried my previous changes over the speaker client and found that I had to test for phone on hook in order to enable startlisteing (as previously mentioned - hs 2.1 does not require the startlistening command) . The attached script test's to see if the phone is off the hook (issuing commands over the phone line or not) and enable's the start listening command as needed.
Thank's for the great script kuntakintayAttached Files
jdr2bpa,
Thanks for posting your edits for those that use hs phone. This should greatly aid those having problems with the script. By the way, glad to hear so many are using the script. Candidly, I didnt really design it rather just re-engineered several non-working scripts into one easy to use one, so I can't take all the credit... ;-)HS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
I fairly new to home seer, and I just down loaded this script. I have a dout about the scripts. I read that you make a manual event then add the wakemeup script to this event. Now, when you make the ohter 4 events do you add the script "wakeup" to these events?
Iam getting this error:
3/31/2008 11:26:25 PM - Warning - Event ID (5) not found for recognized voice command: no
thanksLast edited by Rotech; March 31, 2008, 10:30 PM.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Follow up
I worked with the script again, and I made a trail test. So far I have the computer ask me if I want to be woken up at a certain time and also if is for today or tomorrow.But when the time came around for the wake up call nothing happened.There was no error messages in the log. I noticed 2 things that (for me) was strange:
1: when told to wake up a certain person, it did not confirm the persons name
to be woken up.
2: In the event page under date triggered, it made the event for the wake
up call but the event was disable, is this normal?
I still dont have this going, can any one lend a hand?Hector
Win.2003 OS, HS3
Help needed.
to be woken up.
Win.2003 OS, HS3
