Wakemeup VR Script updated for multiple users and 2.0 compatible Discussion
  • #31
    Enabled Event
    HA! Answered my own question. This solves the problem I was having with the Event not being enabled. I added the last line towards the end of the script. I noticed that the NewTimeEvent name was in the "LogText" string. I just added the "hs.EnableEvent LogText" line at the end of this script section, which then enables the Event that was just created on the line before. For a beginner to HS, this was a big deal. Not sure if this is the best way to solve this, but it worked. Hope this helps.
    If ask = "yes" Then
    system.speak "ok" ' I will wake up " &WhatPerson & " at " + hours + " " + minutes + " " + " in the " + greet
    hs.NewTimeEvent LogText ,StartTime, StartDate, 1, 1, 1, 1, 1, 1, 1, " ", 1,script,"Default"
    • #32
      Date format issue
      I am seeing an issue with the date beging formatted incorrectly depending if the day is a 1 digit or 2 digit day. There is an extra "/" put in if it is a 1 digit day. There is a place to check this in the script, just need to figure out the best way to do it and upload new script version.
      • #33
        Did you ever get this fixed? I'm thinking of installing this script.
        Thanks.
        Steve
        (System configuration is in my profile)
