CID_Search_Notify script comments
  • CID_Search_Notify script comments
    Post comments or questions about the CID_Search_Notify script here.
    Link to script http://board.homeseer.com/showthread...652#post703652
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    Seems to be the best I have used so far. It is looking up the number and saying the name that is found on anywho.
    But,even that it is found in my address book it is still saying what is found on anywho not what is found on my address book.
    I have lingo Voip and know what you are talking about. I love a program that will try to find the number.
    I am also getting a error, which might be some of my problem:
    Running script, script run or compile error in file: CID 3424:Object required: 'hs.Plugin(...)' in line 161 More info: Object required: 'hs.Plugin(...)'
    Maybe you could tell me what is wrong,
    Dan
    danielbo
      Ok glad you are giving it a try. On your error it may be that you dont have the Message server plugin. I use that in the script to send CID info to clients. I use this while I am at work so I can see who is calling the house as well as what HS is doing all day.
      As far as anouncing both phone book entries and any who searches I have not had that hapen to me yet because I would guess maybe thats because most of the people that call me are UN-listed if there in my phone book. In any case it should not do a anywho search unless there is no phone book entry found.
      I will look and see if I missed something.
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
        I still have something wrong.
        I am still getting the error:
        <TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGType1 align=left colSpan=3>Error </TD><TD class=LOGEntry1 align=left colSpan=8>Running script, script run or compile error in file: CID_Search_Notify.txt424:Object required: 'hs.Plugin(...)' in line 161 More info: Object required: 'hs.Plugin(...)'
        Not sure why. I did find on the original that I copied, it didnt have a (end sub). But that did not get rid of this error. I am not getting it to say the state in not found by the erea code either. Maybe you could look at what I have and see if something still did not copy right.
        </TD></TR></TBODY></TABLE>
        Sub Main()
        dim i, line, adr_count, contact
        dim callname, callnmbr, dhit, addbk
        dim objMsg, strTitle, strMsg, strMsgSent
        dim num, p, tmp, url
        dim pg, nml, posl
        dim nmf, caller, ref
        dim ac, pos, pos2, st
        dim adnum, flag
        dim ct, tmr, num1, num2
        dim sec, f, fso, loops
        dim sl, old, callerid
        dim bedtime, path, bathtime
        sc=timer
        ' get the caller directory name
        callname = hsp.cidname(1)
        ' get the phone number
        callnmbr = hsp.cidnumber(1)
        'callnmbr=2604329996 'for testing
        'callname="O" 'for testing
        'hs.writelog "CID_Search_Notify DEBUG Phone Number Var",callnmbr
        if callname = "O" then
        callname = "*Out of Area"
        end if
        if callname = "P" then
        callname = "*Private"
        end if
        ' init the directory hit flag
        dhit = false
        ' number of address book entries
        adr_count = hsp.ADRCount
        ' reverse if last, first format
        if instr(1,callname,",") then
        callname = trim(hs.stringItem(callname,2,",")&" "&hs.stringItem(callname,1,","))
        end if
        if left(callnmbr,1) <> "*" then
        'Is it a CID message, skip formatting
        if instr(1,callnmbr,"-") = 0 then
        'Are the dashes missing?
        callnmbr = trim(callnmbr)
        'format it for voice if dashes are missing
        callnmbr = left(callnmbr,3)&"-"&mid(callnmbr,4,3)&"-"&right(callnmbr,4)
        end if
        end if
        for i = 1 to adr_count ' look thru address book for number
        set contact = hsp.ADRGet(i) ' get the reference to the addrbk entry
        select case callnmbr ' see if the number is in the book
        case contact.home_phone
        callname = contact.first&" "&contact.last ' pickup the name
        addbk = "Home number" ' denote the source
        dhit = true ' we had a hit in the address book
        exit for ' performance - exit loop if found
        case contact.cell_phone
        addbk = "Cell number"
        dhit = true
        exit for
        case contact.business_phone
        addbk = "Work number"
        dhit = true
        exit for
        case contact.home_phone_2
        addbk = "Home number 2" ' denote the source
        case contact.cell_phone_2
        addbk = "Cell number 2"
        dhit = true
        exit for
        case contact.business_phone_2
        addbk = "Work number 2"
        dhit = true
        exit for
        end select
        next
        if dhit = false then
        addbk = "AT&T directory"
        end if
        If callname="*Out of Area" or callname="O" or callname="*Private" or callname="P" or callname="Unavailable" Then callname=""
        If callname="" and callnmbr<>"" Then
        num1=Left(callnmbr,3)
        num2=Right(callnmbr,8)
        url="http://www.anywho.com/qry/wp_rl?npa=" & num1 & "&telephone=" & num2 & "&btnsubmit.x=22&btnsubmit.y=16"
        pg=hs.GetURL(url,"",FALSE,80)
        posl=InStr(pg,"<!-- listing -->")+83
        If posl=83 Then
        callname=""
        Else
        i=0
        nml=""
        tmp=Mid(pg,posl+i,1)
        While tmp <> "," and tmp <> "<"
        nml=nml & tmp
        i=i+1
        Wend
        If tmp <> "," Then
        nmf=""
        Else
        nmf=""
        i=i+2
        While tmp <> "<"
        nmf=nmf & tmp
        i=i+1
        Wend
        End If
        If InStr(nml,"TABLE BORDER=") <> 0 Then nml=""
        callname=nmf & " " & nml
        If callname=" " Then callname=""
        End If
        End If
        ac=""
        If (callname="" and callnmbr <> "") or callname="Pay Phone" Then
        Set fso = CreateObject("Scripting.FileSystemObject")
        Set f = fso.opentextfile("c:\program files\homeseer 2\scripts\areacode.txt",1)
        ac=f.readall
        f.Close
        st="<a name=" & Chr(34) & Left(callnmbr,3)
        pos=InStr(ac,st)
        st= Mid(ac,pos+25,30)
        pos2=InStr(st,":")
        If callname="Pay Phone" Then
        callname="Pay Phone" & Mid(st,1,pos2-1)
        Else
        callname="Area code" & Mid(st,1,pos2-1)
        End If
        End If
        hs.WriteLog "Caller Searched Result", callname
        If callname="" Then callname = "Unknown Caller."
        hs.Speak callname
        flag=0
        tmr=Timer
        ct=hsp.LINERingCount(1)
        While flag=0
        While ct=hsp.LINERingCount(1) and flag=0
        hs.WaitEvents
        If Timer-tmr > 10 or hsp.LINERingCount(1) > 3 Then flag=1
        Wend
        If flag=0 Then hs.Speak callname
        Wend
        ' Script: Derived from MS_SendMsg.txt v1.0.2 by Christian Yvinec
        'objMsg.Data = strMsg 'The text message As String
        'objMsg.Title = strTitle 'Optional the title for ballons or MsgBox As String
        'objMsg.Icon = Alert 'Optional the image for ballons As Integer
        'objMsg.Balloons = true 'Optional show balloons As Boolean
        'objMsg.Mbox = true 'Optional show MsgBox As Boolean
        'objMsg.IP = "192.168.1.150" 'Optional To Client IP As String - null for all connected clients
        'strMsgSent = objMsg.SendMsg 'Send the message to client (Return confirmation)
        Const None = 0, Info = 1, Alert = 2, Error = 3
        Set objMsg = hs.Plugin("Message Server").SendObject
        objMsg.Data = "Incoming Call from: " &callname &" "&callnmbr &" "&addbk ' The message to send
        objMsg.Title = callname
        objMsg.Icon = info ' Type of message
        objMsg.Balloons = False ' Use a popup balloon
        objMsg.Mbox = True ' Display only the balloon
        objMsg.IP = ""
        strMsgSent = objMsg.SendMsg ' send the message to the client(s)
        hs.writelog "MS sent", objMsg.data
        Set objMsg = Nothing
        Set ms = Nothing
        'send an email to my cell phone which arrives in the form of a text message.
        TOaddress = "xxx@xxx.com"
        FROMaddress = "xxx@xxx.com"
        subject = "Incoming Call"
        body = "Caller: "&callname &" Number: "&callnmbr &" Description: "&addbk
        hs.SendEmail TOaddress, FROMaddress, subject, body
        'Put last caller info into a Device.
        virtualdevice = "z98"
        hs.SetDeviceString virtualdevice,"<img src=\Images\phone.gif>"&callname&" "&callnmbr&" "&addbk, True
        hs.WriteLog "Device updated Last Caller",callname & callnumbr & addbk
        end sub
        I have the ereacode.txt with in the script file and I am also running homeseer speaker.
        I have looked and couldnt find anything, but then again I am not real good at programing.
        Thanks and keep up the great work,
        Dan
        danielbo
          Looks like part of the sript is missing between st=line and callname=Pay Phone
          pos=
          InStr(ac,st)
          st=
          Mid(ac,pos+25,30)
          pos2=
          InStr(st,":")
          If callname="Pay Phone"Then
          Else
          HS2 Environment
          HomeSeer Way2Call
          Netiom-Xap board
          opnode 1-wire 1.2.7
          Plug-In's
          WeatherXML 1.0.0.32
          mcsTemp V6.2.0.14
          RFXCOM 15.0.0.22
          Odroid X2
          Asterisk 11.5.1
          FreePBX 2.11.0.42
          WebMin 1.720
            danielbo
            I checked the script its in what I posted. Did you modify the script by chance?
            Also
            Are you running HS2?
            Do you have the message server plugin installed?
            it may be why your getting this error. line 161 is right were Message server begins.
            HS2 Environment
            HomeSeer Way2Call
            Netiom-Xap board
            opnode 1-wire 1.2.7
            Plug-In's
            WeatherXML 1.0.0.32
            mcsTemp V6.2.0.14
            RFXCOM 15.0.0.22
            Odroid X2
            Asterisk 11.5.1
            FreePBX 2.11.0.42
            WebMin 1.720
              I will try this!!
              No way, I would never touch a good thing. I really think you did a great job and I hope more people will find it helpful and appreciate what you have done and you have been a great help to me.
              yourself@yourself.com. The one I copied the second time also has the endsub. So maybe I copied the wrong one. I will try it again, hopefully without errors. <O
              Thank you for your great help and good job.<O
              Dan<O
              danielbo
                oops your right I put my script that I was using which had email addresses in it.Thanks for telling me. I must have been half a sleep. All better now.
                No problem let me know how you make out.
                HS2 Environment
                HomeSeer Way2Call
                Netiom-Xap board
                opnode 1-wire 1.2.7
                Plug-In's
                WeatherXML 1.0.0.32
                mcsTemp V6.2.0.14
                RFXCOM 15.0.0.22
                Odroid X2
                Asterisk 11.5.1
                FreePBX 2.11.0.42
                WebMin 1.720
                  Set objMsg = hs.Plugin(&quot;Message Server&quot.SendObject
                  I know its the line that says
                  that is giving me the error, I believe I need to install a message server plugin.
                  Would you know where I would find such a thing. I check updates.
                  Dan
                  danielbo
                    Yhea Dan
                    I was able to delete that section and all runs fine for me now. I am even getting the email notifications that I wasnt.
                    LOVE IT !!!!!!!!
                    Thanks guy, anything else you want me to try,just yell. I can be your worse nightmare.
                    Really mean it, Thanks,
                    Dan
                    danielbo
                      OK another Problem
                      It really seems as if it is working pretty good. But now it is seeming that everything is coming up as north new jersey.
                      Any Ideas?
                      Dan
                      danielbo
                        Where is this script posted? I would love to try it out, if you don't mind.
                        jjsmd@yahoo.com
                          Sorry, I found it.
                          jjsmd@yahoo.com
                            My too, everything is coming up as North New Jersey.
                            Any Ideas?
                              Check your HS 2 log and let me know what number your CID device is recieving. I could then plug it in on my end and test.
                              It may be
                              I am thinking if it for some reason it is not getting an area code number to search for or possibly the area code it is looking for is not present in the list.
                              It will look through the areacode text file and that Area code North NJ is at the top of the list first entry and speaks that.
                              Also note that the area code list is not up to date
                              Note script updated
                              I have since set the script to announce CID name 4 times and it is adjustable to what ever you want
                              HS2 Environment
                              HomeSeer Way2Call
                              Netiom-Xap board
                              opnode 1-wire 1.2.7
                              Plug-In's
                              WeatherXML 1.0.0.32
                              mcsTemp V6.2.0.14
                              RFXCOM 15.0.0.22
                              Odroid X2
                              Asterisk 11.5.1
                              FreePBX 2.11.0.42
                              WebMin 1.720
