Modification History Discussion
    Hope you like it :P
    ASP can be found HERE
    -Tom
    Visit Kernhome
    Kern Theater Gallery
    (User: guest / Pass: guest)
    Tom,
    I installed the files and when trying the asp file get this error..
    Script error: Object required: 'hs.plugin(...)'
    response.write Cstr( hs.plugin("Web Wrapper").Header("Modification History",0, False))
    response.write Cstr( hs.plugin("Web Wrapper").Header("Modification History",0, False))</PRE>
    </PRE>
    Any ideas.</PRE>
    </PRE>
    Thanks</PRE>
    </PRE>
    Thom</PRE>
      Yeah, I use WebWrapper where most people use the built in custom header and footers. I'll change the zip and that should get you going.
      -Tom
      Visit Kernhome
        Thanks Tom works great..
          I have been looking for something like this for ages...thanks
            Very nice util - thanks!
            68 Z-Wave Nodes, 175 Events, 359 Devices
              As a matter of interest...so I know what file to keep backup of....where is the data kept?
                Glad you guys found it useful I'll see if I can work on some of the enhancements I had planned.
                The data is stored in this file: \config\ModHistory.csv
                -Tom
                Visit Kernhome
                  Anyone know if this works on Linux? Just getting a blank page with the Device List top bar.
                    Have never tried it on linux, but will spin up my linux laptop and try it over the next few days.
                    Cheers
                    Al
                      ASP is not supported on Linux as it is based on VBScript. It would need to be converted to ASPX which works on Linux apart from Zee builds of HS3.
                      Jon
                        There is a version compatible with Linux here: https://forums.homeseer.com/showpost...34&postcount=7
                        Jon
                          Jon,
                          I wanted to update my working modhistory.asp to your updated one, however there appears to be an issue in the output of the date as you can see.
                          Looks like the space/tab character is getting interpreted to question marks.
                          Would you mind taking a look when you have time?
                          Robert
                            Woiuld you be able to send me your Modhistory.ini file to look at?
                            Are you on the latest beta of HS3?
                            Jon
                              Jon, There's no modhistory.ini. Do you mean modhistory.csv?
                              I'm running on the rock solid .318. Never had a chance to jump to the latest yet.
                              Robert
