Maintenance & Reminders Discussion
    #16
    Originally posted by Tom Kern View Post
    For your second question where it was carrying the first device through, does that mean you were using the script to reconfigure via input boxes? The configurator is supposed to allow you to choose which house and device codes you want for each device and I think it displays the current one you are editing in the titlebar. Also, I can't remember offhand, but I don't think it creates the devices for you. The ASP should read the AddHouseCode key above for which house code you are looking to use. The default if there is none specified is definitely "M", perhaps that is why it locked you into it.
    Not sure about the locations, I'll have to look into how Stephan is populating that combobox.
    Hello Tom,
    Did you ever find out what was forcing the M house code? I'm having the same problem. I created a reminder with the house code N1 (since I'm using M for another application) and when I bring the ASP page up, it gives me drop down options from M1 to M16.
    Todd
    -Todd
    ____________________________________________________________ ________________
    HS2Pro: 2.5.0.81 :: HS3Pro (beta) || Plugins:| SmartHome PowerLinc USB, Global Cache, BLBackup, DooCPU Monitor, DooMotion, BLOutlook, BLIcon, BLOutgoingCalls, OutgoingCalls, ROC-Rnd, HSTouch iPhone, UPS Monitor, DooMenuBar, BLSpeech, HSTouch Server, WAF AB8SS, mcsTemperature, VWS, BLChart, RFXCOM, ISY Insteon, iAutomate RFID, iTunes, NetCAM, DSC Security, Nest
      #17
      Maintenance Instructions
      Don't know if anyone still uses it but I thought I would write some instructions might be useful for the new guys. (their is more info in the header of the script as well.)
      Version:-
      Script by Tom Kern created on 03.04.03
      Mainten.asp 1.0.1 by StePhan McKillen
      To get setup this is what you do:-
      1 Place Mainten.asp in the HTML folder.
      2 Place Maintenance.vbs in the SCRIPTS folder.
      3 Place GreenCheckSmall.gif, BlankBkGrnd.gif into the HTML\IMAGES folder.
      Create a recurring event called Refresh Maintenance to run the Maintenance.vbs script once a day. This checks to see what reminders are due.
      Create a manual event called Setup Maintenance to run Maintenance.vbs script and in the Optional parameters box enter ("main","change") including the brackets. This allows you to setup your reminders and create new ones.
      Create a manual event called Clear Maintenance to run Maintenance.vbs script and in the Optional parameters box enter ("main","clearini") including the brackets. This clears all previous settings.
      Now using your main Homeseer PC run the Setup Maintenance event and you should get a setup box asking the following:-
      1. How many total devices would you like to configure? (Over estimate as they can be disabled until needed!)
      2. What house code & device code do you want to use for each?
      3. Enter a maintenance date for each item
      4. Enter the maintenance message for each item
      5. Enter number of days when a warning message is displayed (Optional)
      6. Enter a warning message for this maintenance item (Optional)
      7. Enter an Email Address (Optional)
      !!!!!! For some reason the data from the previous device is automatically entered in to each field !!!!!!
      Once you have entered these details call the mainten.asp page from Homeseer i.e http://localhost:80/mainten.asp
      You will see a page with all the devices you entered correct any mistakes you may have made choose the schedule period and click update.
      You need to manually create the devices in Homeseer once this is done run the Refresh Maintenance event once and viola your reminders are on the status page.
      You can change any of the reminders setting by going back to the mainten.asp page. once you run the Setup Maintenance event or the Clear Maintenance event it is not possible to make changes using the mainten.asp page.
      !!!! KEEP A COPY OF ALL YOUR REMINDERS AND DEVICE CODES !!!!
      TROUBLESHOOTING
      If your gettin the following error
      Script error: Type mismatch: 'CInt' For i = 1 To CInt(NumDevices) KeyInfo = Trim(hs.GetINISetting("Maintenance", "MData" & CStr(i), ""))
      You are not on the main Homeseer PC
      Hope it's of help
      Mark
      Last edited by wher2guv; March 20, 2008, 08:47 PM. Reason: Added which version I was on about
        #18
        Current Version
        Is there a new version?
        Bill Hogsett
          #19
          No but I thought that it might be of some use to have the instructions.
          I have just reinstalled it and have had to get my head round how to do it so thought I would write it down this time.
          Mark
            #20
            e-mail error
            Mark, I have now setup your maintenance script.
            I get this error message in the log:
            3/28/2008 6:06:30 AM - Warning - Sending email To: billhogsett@eaton.com aborted after 4 tries
            3/28/2008 6:06:30 AM - Error - Sending email using SMTP: At least one of the From or Sender fields is required, and neither was found.
            3/28/2008 6:06:00 AM - Error - Sending email using SMTP: At least one of the From or Sender fields is required, and neither was found.
            3/28/2008 6:05:30 AM - Error - Sending email using SMTP: At least one of the From or Sender fields is required, and neither was found.
            3/28/2008 6:05:00 AM - Error - Sending email using SMTP: At least one of the From or Sender fields is required, and neither was found.
            3/28/2008 6:05:00 AM - Maintenance - Status: Make and appointment and then get oil changed (2 Days)
            (read from the bottom up)
            I suspect it is my HS e-mail configuration. But other scripts (eg. CNN alerts) send e-mail.
            Any suggestions?
            Bill
              #21
              What exactly does this script do? Is this for reminder to do things? and whats special about this script comparing this with the calender script in HS?
              Hector
              Win.2003 OS, HS3
              MyTrigger,ACRF2,W800,Zwave
              AP800,Honeywell Stat
                #22
                Sorry bill I didn't write the script I just tried to make the instructions a bit easier I don't use it to send emails myself. I'm working for the next few days but on my next day off I'll have a go and se if I can get it to work.
                  #23
                  Thanks, I'll see if I can get it working myself and post any fixes.
                  Bill
                    #24
                    Hi bill had a quick look this morning I think you need to have a default senders email address in the homeseer email setup.
                      #25
                      Yes this just makes a device for each reminder and gives the status of the reminder and how many days till it's due.
                      I can't compare the two I haven't used the calender script.
                      I just wrote some install instructions for this because I had it installed then when I had to reinstall everything and I couldn't remember how I installed it originally.
                      I wrote it down this time and thought it might be useful to someone else, plus if I need to install again I can find my post. (paper gets lost in my house)
                        #26
                        Hi, first well done for this pluging... it's a good idea !
                        But i have a strange message
                        Script error: Type incompatible: 'CDate'
                        iTemp = DateDiff("D", Now, CDate(ChangeDate))
                        'Write data to page
                        for me, my format date is like that : 13 septembre 2008
                        could you help me?
                        thx
                        Thierry From France
                          #27
                          For anybody else trying to setup this script
                          Th email errors seen here:
                          Any suggestions?
                          Bill
                          Can be fixed by editing the Maintenance.vbs script and changing this line
                          Const HomeSeerEmailAddress = ""
                          to reflect what you want as a "From:" address on the email message
                          Const HomeSeerEmailAddress = "HSMaintenance@yourdomain.com"
                          If you do this small script change and follow the *GREAT* instructions provided by Mark in post #17 it will run like a champ! Mine does!
                          Good luck!
                          Steve
                          (System configuration is in my profile)
