I will try that tonight MeSteve (i am at work too )
Gogs, that maybe what is causing my problem as i had put a zero for Labor day and Memorial Day.
Neil
Days Till Reminder Script Discussion
Got it up and running with 2 problems.
1. I have to leave Mothers day Fathers Day etc all set to 1 in the ini, if I set them to 0 I get rubbish.
2. I have 4 dates set up as followsCode:EventDate(0)=01/01 EventDate(1)=02/14 EventDate(2)=10/31 EventDate(3)=12/25
Anyone shed some light in this?
just fyi, the second reminder in my setup should be new years day
Neil
Guest repliedI don't know what is going on, I can't get it to do it here. I will look some more tomorrow.
Ok,
i tried your new files and don;t get any errors.
However Reminder 2 is still weird - it says that there are currently -
23 days till Memorial Day 107th
I actually have memorial day set to "0" in the ini file
Any ideas what this may be?
Neil
The biggest issue was the ini file called the Virtual devices something different from the txt file. e.g in the ini file the house code was called remindercode but in the txt file it was called housecode.
Also i moved the dim unitcode higher up in the script as it was being defined after it was being used (that was the cause of the original error at line 246)
I will give your new files a try.
Neil
Guest repliedTry these versions.
What fixes did you make?
NOTE: I changed the device codes.
MeSteve
I just installed your script and got the same errors. I have found the bugs in the script and corrected them. - I am no scripting expert but think i got it right. It now works on my system anyway.
Attached are the modified files.
I am however getting a weird reminder as reminder 2.
Right now it shows:
reminder 1 - 18 days till christmas
reminder 2 - 23 days til 107th
Any ideas?
NeilAttached Files
Guest repliedI am going to guess that there is a value in your .ini that the script doesn't think is a date. Check those out and make sure. If not, if you could send my your .ini I will take a look to see if I can duplicate the problem. NOTE: I am leaving for vacation for a few weeks so if I get it soon I can take a look, otherwise, it will have to wait till I get back.
Guest repliedRun error
Hi Steve,
I get the following message, Running script,script or compile error in file: Days_Till_Reminder_Ver3.13.txt13:Type mismatch:'DaysTo' in line 246 More info:type mismatch: 'DaysTo'
What did I miss?
Mike
Post comments/questions about Days Till Reminder Script Here
NOTE: The daylight savings portion is setup to the new rules starting next year (2007). As a result, the daylight savings reminder will be in November this year (2006), not at the correct date.Tags: None
