Oil per Barrel Price Script
  • Oil per Barrel Price Script
    Any one have a script to track the oil per barrel price? and put it into a device?or speak it?
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    this will give you a start...
    Stuart
      Thanks Stuart could not have do it with out you. Here is the script works fine.
      HS2 Environment
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      mcsTemp V6.2.0.14
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
        Question, what is the purpose of replacing "" with ""? And why 3 times?
        Strdata = Replace(Strdata,"","")
          Steve,
          The script posted doesn't have those lines. Maybe it was updated.
          HTML Code:
          Dim startint
          Dim Endint
          Dim Strdata
          Sub main()
          	Strdata = hs.GetURL("www.quoteoil.com", "" & strZip, true, 80)
                  Strdata = Replace (Strdata, chr(9), "")
                  Strdata = Replace (Strdata, chr(10),"")
                  Strdata = Replace (Strdata, chr(13), "")
                  Strdata = Replace(Strdata,"<b>","")
                  Strdata = Replace(Strdata,"<br >","")
                  Strdata = Replace(Strdata,"</b>","")
          	startint = InStr(Strdata, "$")
          	Endint = InStr(startint, Strdata, "per barrel") + 10
          	strquote = Trim(Mid(Strdata, startint, Endint - startint ))
                  Strquote= "Oil is " & strquote
          	hs.speak strquote
                  end sub
          -Rupp
            The second version does.
              Hi,
              when i first posted the script, I had to make the file an attachment, it didnt like the format.
              Stuart
                Don't know how I did that cut and past is all I did to start. Thanks Rupp (Hawk eye)
                I have corrected the previous post.
                Works great
                HS2 Environment
                HomeSeer Way2Call
                Netiom-Xap board
                opnode 1-wire 1.2.7
                Plug-In's
                WeatherXML 1.0.0.32
                mcsTemp V6.2.0.14
                RFXCOM 15.0.0.22
                Odroid X2
                Asterisk 11.5.1
                FreePBX 2.11.0.42
                WebMin 1.720
                  Oil is $ per barrell
                  Anyone else getting the above string when going to quoteoil.com?
                  Just wondering, Later Terry
                    Originally posted by tman1
                    Anyone else getting the above string when going to oilquote.com?
                    Yes, just got it this morning.
                    Scott
                      The site that the script gets its info from has no price present.
                      www.quoteoil.com
                      HS2 Environment
                      HomeSeer Way2Call
                      Netiom-Xap board
                      opnode 1-wire 1.2.7
                      Plug-In's
                      WeatherXML 1.0.0.32
                      mcsTemp V6.2.0.14
                      RFXCOM 15.0.0.22
                      Odroid X2
                      Asterisk 11.5.1
                      FreePBX 2.11.0.42
                      WebMin 1.720
                        Oil Price Script stopped working
                        This was working but now when the script runs I get bellow:
                        Speak ():Oil is $(document).ready(function() { $("#responsecontainer").fadeOut(75).load("reload.php").fadeI n(75); $("#responsecontainer2").fadeOut(75).load("reload2.php").fad eIn(75); var refreshId = setInterval(function() { $("#responsecontainer").fadeOut(75).load('reload.php?randval ='+ Math.random()).fadeIn(75); $("#responsecontainer2").fadeOut(75).load('reload2.php?randv al='+ Math.random()).fadeIn(75); }, 7500);});en ar es fr de ru zhPrice of OilLight sweet crude oil-->$91.69 per barrel
                        I believe the web page changed a bit. Is there a fix that some one can offer? Thank you
                        The script I am running is attached.
                        HS2 Environment
                        HomeSeer Way2Call
                        Netiom-Xap board
                        opnode 1-wire 1.2.7
                        Plug-In's
                        WeatherXML 1.0.0.32
                        mcsTemp V6.2.0.14
                        RFXCOM 15.0.0.22
                        Odroid X2
                        Asterisk 11.5.1
                        FreePBX 2.11.0.42
                        WebMin 1.720
                          This is a quick way (there may be better ways),
                          Dim Strdata
                          Dim LenStr
                          Sub main()
                          Strdata = hs.GetURL("www.quoteoil.com", "" & strZip, False, 80)
                          LenStr = (Instr(strData, "< strong >") + 8) - (Instr(strData, "< /strong >") - 9)
                          strQuote = Mid(StrData, Instr(strData, "< strong >") + 8, LenStr + 1)
                          Strquote = "Oil is " & strquote
                          system.speak "C:\program files\HomeSeer HS2\wave\ToneAnnounce.wav",False
                          hs.WaitSecs 1
                          hs.system.speak strquote
                          virtualdevice = "N91"
                          hs.SetDeviceString virtualdevice,"" & Strquote, True
                          End Sub
                          Hopefully it works if the price goes above $100/barrel, thats the only problem I see - unless they change the page again
                          The board has a problem as it tries to parse the < strong > tags, please take the spaces out when you copy it into a script...
                          My Plugins:
                          Yeelight 3P | Nanoleaf 3P
                            This works now
                              YES that fixed it THANKS!!!
                              HS2 Environment
                              HomeSeer Way2Call
                              Netiom-Xap board
                              opnode 1-wire 1.2.7
                              Plug-In's
                              WeatherXML 1.0.0.32
                              mcsTemp V6.2.0.14
                              RFXCOM 15.0.0.22
                              Odroid X2
                              Asterisk 11.5.1
                              FreePBX 2.11.0.42
                              WebMin 1.720
