Package Tracker Discussion
    #16
    MeSteve,
    First of all, this is a great script.
    I am having the same problem with Package Tracker that DV was having. If I look at the page received from the URL it shows jscript code only, no data. What needs to be changed to retrieve the correct information (and eliminate the error)? I am trying to track USPS shipments.
    the specific error is:
    1/5/2007 6:46:59 AM - Error - Running script, script run or compile error in file: Package_Tracker.txt5:Invalid procedure call or argument: 'mid' in line 58 More info: Invalid procedure call or argument: 'mid'
    Line (57 & )58 is:
    strLastscan = strBody
    strLastscan = Mid(strLastscan,Instr(strLastscan,"Scan History:"))
    and of course:
    strBody = hs.GetUrl(strHost,strPage,false,80)
    TIA,
    Mitch
    http://www.midondesign.com
      #17
      OK, I found the problem. iShip is not providing Scan information for USPS so the script errors out. I changed the routine to be:
      if Instr(strLastscan,"Scan History:") <>0 then
      strLastscan = Mid(strLastscan,Instr(strLastscan,"0"">")+3)
      strTmp = Mid(strLastscan,1,Instr(strLastscan,"<")-1)
      strLastscan = strTmp & " " & Mid(strLastscan,1,Instr(strLastscan,"<")-1)
      else
      strLastscan = "Scan History: not available"
      end if
      Also, I changed the routine at the end from:
      elseif strCarrier = "USPS" then
      to:
      elseif strCarrier = "US Postal Service" then
      Mitch
        #18
        First of all, I have yet to actually track a USPS package successfully. Glad you got it working. Could you still PM me your tracking number so I can see what exactly is going on, because I don't get errors.
          #19
          I'm also getting the same error on "mid" on two packages, one UPS, one USPS.
          Turns out that the script needs an error handling routine for when the tracking numbers are not yet in the system. When Iship.com displays a "We are unable to track..." it causes the script to error out and stop processing.
          I've attached my attempt at dealing with this.
          Also, the creator script is having issues dealing with multiple inbound email. If there are 2 incoming and the housecode is "T", it does the following.
          Create T1 with Tracking number 1
          Create T4 with Tracking number 2
          Create T2 with name from #2
          Create T5 with name from #1
          Create T3 with name from #2
          Create T6 with name from #1
          It basically fills in the wrong names for the virtual devices.
            #20
            Still Working
            I this still working with Fedex?
            I have a package that was delivered but never showed that is was in HS devices
            HS2 Environment
            Zotac 1.83 GHz Quadcore
            HomeSeer Way2Call
            Netiom-Xap board
            opnode 1-wire 1.2.7
            Plug-In's
            WeatherXML 1.0.0.32
            Pwr Link USB 1.0.0.13
            mcsTemp V6.2.0.14
            mcsXap V3.0.0.0/3.0.0.20
            IM Connector 4.87.2.5
            Sip Connector 2.56.2.4
            RFXCOM 15.0.0.22
            Odroid X2
            Asterisk 11.5.1
            FreePBX 2.11.0.42
            WebMin 1.720
            Xap Switchboard by Mi4
            There is no place Like 127.0.0.1
              #21
              I appologize, been really busy lately. Did it ever get updated or did you just delete the devices. I have noticed that there are certain services that are not updated by this site. Most USPS services are not updated as well as some FedEx. Those are the only ones I personnally have seen, there may be more that I have not heard of, but no one has mentioned any yet. I am not sure I will have the time in the near future to get this script updated. If someone wants to take a look at it, feel free.
                #22
                Thanks for the reply. Yes I just deleted the devices. But the carrer I was refering to was Fedex I asked if it was working because I modifided your script to use Jon00's email program. I was wondering if I broke it.
                HS2 Environment
                HomeSeer Way2Call
                Netiom-Xap board
                opnode 1-wire 1.2.7
                Plug-In's
                WeatherXML 1.0.0.32
                mcsTemp V6.2.0.14
                RFXCOM 15.0.0.22
                Odroid X2
                Asterisk 11.5.1
                FreePBX 2.11.0.42
                WebMin 1.720
                  #23
                  Is this script still working? I am getting an error of:
                  Running script, script run or compile error in file: Package_Tracker.txt5:Invalid procedure call or argument: 'mid' in line 63 More info: Invalid procedure call or argument: 'mid'
                  HS2 Environment
                  HomeSeer Way2Call
                  Netiom-Xap board
                  opnode 1-wire 1.2.7
                  Plug-In's
                  WeatherXML 1.0.0.32
                  mcsTemp V6.2.0.14
                  RFXCOM 15.0.0.22
                  Odroid X2
                  Asterisk 11.5.1
                  FreePBX 2.11.0.42
                  WebMin 1.720
                    #24
                    Any one still using this script? Just wondering if it is something on my end.
                    I am tring to track a fedex package. I get the error above
                    HS2 Environment
                    HomeSeer Way2Call
                    Netiom-Xap board
                    opnode 1-wire 1.2.7
                    Plug-In's
                    WeatherXML 1.0.0.32
                    mcsTemp V6.2.0.14
                    RFXCOM 15.0.0.22
                    Odroid X2
                    Asterisk 11.5.1
                    FreePBX 2.11.0.42
                    WebMin 1.720
