getmyip seems to be not working lately. So, I wrote this simple vb script to get ip & post the htm file to your host page.
'Code starts here
Dim getHost As String = "www.edpsciences.com"
Dim getPage As String = "/htbin/ipaddress"
Dim getStripTags As Boolean = False
Dim getPort As Integer = 80
Dim putHost As String = "your host name" ' something like "upload.comcast.net"
Dim putUserName As String = "youruserid"
Dim putPassword As String = "yourftppassword"
Dim putCommand As String = "put"
Dim putPath As String = ""
Dim putLocalFile As String = "ip.htm"
Dim putRemoteFile As String = "ip.htm"
Sub Main(parm as object)
Dim content As String = hs.GetURL(getHost, getPage, getStripTags, getPort)
'hs.WriteLog("GETIP", content)
Dim sr As System.IO.StreamReader = New System.IO.StreamReader(putLocalFile)
Dim oldContent As String = sr.ReadToEnd()
sr.Close()
'hs.WriteLog("GETIP", "oldContent = " & oldContent)
Dim sw As System.IO.StreamWriter = System.IO.File.CreateText(putLocalFile)
sw.Write(content)
sw.Flush()
sw.Close()
If String.Compare(oldContent, content) <> 0
hs.WriteLog("GETIP", "ftp new ip")
hs.ftp(putHost, putUserName, putPassword, putCommand, putPath, putLocalFile, putRemoteFile)
End If
End Sub
'Code starts here
sr.Close()
sw.Write(content)
sw.Flush()
sw.Close()
End If
End Sub
