UK Threat level
    UK Threat level
    Hi all,
    I seem to remember there was a script developed to periodically download the US threat level and display it in Homeseer. The obvious advantage of this is that you could then perform an action if this threat level changed.
    As most of you in the UK know, we recently made our threat levels public and they are now available on a number of websites. Is anyone looking to develop a scipt to download this information into homeseer?
    The information is available in a number of places such as http://www.homeoffice.gov.uk/securit...-threat-level/ and a number of other public sites although i have not managed to find a site that presents it in an easily checkable form.
    Would love to know if anyone knows how to do this and is thinking of developing something
    Here's the Homeland security script. It shouldn't be too hard to convert over.
    http://board.homeseer.com/showthread...light=homeland
    -Rupp
      mdeakin,
      I would suggest dropping our UK script genius Jon00 a line... he writes lots of useful stuff for us UK based people.. if its a site that can be scraped he will be able to do it if he isnt too busy.
      Normally I would ask but my donations only cover so much most of my HS has been Jon00`fied
      TrOjAn
        Ok,
        I wrote a quicky script and posted it here:
        http://board.homeseer.com/showthread...510#post726510
        -Rupp
          Dang it. I spent at least 10 minutes yesterday writing my own.
            Excellent stuff. I went for sjcato's in the end as I was after a simply 'critical', 'severe' etc so that I could then perform other actions when it changed.
            Thanks for ALL your efforts .. sterling work !
              I do not normally comment after I have altered another persons script.
              I went for Rupp's, it was the first published, and adapted it as all I wished was Critical etc.
              Like you I wished to "modify" the output. I have not tried sjcato's script; yet.
              The modifications I made to Rupp's script worked fine until they changed the alert status, I had not allowed for the complete string being changed, thought they would only change to actual status.
              So back to the drawing board so to speak.
              Last edited by Gogs; August 14, 2006, 04:49 AM. Reason: Modifications failed when status changed.
                I am trying your script too. Unfortunately I am getting the following error when I run it
                Running script, script run or compile error in file: UKThreat[1].vb.txt1006:Expected ')' in line 1 More info: Expected ')'
                I have had a look at the script and can find nothing wrong.
                Any Ideas?
                  Gogs,
                  Its a VB.NET script. Steve added the .txt at the end to post it on the board. Just rename it as UKThreat.vb
                  Jon
                    Originally posted by jon00
                    Gogs,
                    Ahh, that simple, OK.
                    Thanks Jon.
                      Removed the txt bit, and now what an error
                      Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentException: Argument 'Start' must be greater than zero. at Microsoft.VisualBasic.Strings.Mid(String str, Int32 Start, Int32 Length) at scriptcode5.scriptcode5.Main(Object param) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
                      Any sugestion, Jon?
                        Gogs,
                        I just checked and I too have had that error intermittently. It is a run rime error. I think the web page retrieve is failing to complete - possibly the page is overloaded.
                        This would cause the variable b1 to become 0. I have added a check so the rest of the script is skipped if b1 is zero. This wont reset the status but won't give you the error message.
                        Steve
                          Actually, just seen what the real problem is. They changed the site already - it went from "The current threat level is " to "The current terrorism threat level is "
                          Just add the word "terrorism" to fix it in the script.
                          When are government entities going to catch on that RSS is needed.
                            Hi, I thought I might grab the bull by the horns and sent an email to the owners of the Home Office site. Not sure if I will ever get a response but I can but try :-)
                            Will let you all know how I do :-)
                              Look out the window if theres a knock at the door
                              TrOjAn
