Contacting HomeSeer This Week
See more
See less
Converting scripts Help Please
  • Converting scripts Help Please
    How do you convet a simple script like this to a .vb script
    Thom
    PHP Code:
    Sub main()
    Dim Path
    Dim Pathloc
    Dim strng
    Dim Stcolor
    Path
    ="http://192.168.0.1"
    Pathloc="/status/status_bar.html"
    strng=hs.GetURL(Path,Pathloc,False,80
    Stcolor=hs.stringitem (strng,2,"src=/fs/images/"
    Stcolor=hs.stringitem (Stcolor,1,".GIF"
    If
    Lcase(Stcolor)="green" then
        hs
    .SetDeviceString "s55""<img src='/images/green.gif'> <font color='Green'> Satellite Up"
    elseif Lcase(Stcolor)="yellow" then
        hs
    .SetDeviceString "s55""<img src='/images/yellow.gif'> <font color='Yellow'> Satellite Degraded"
    hs.Speak "Direc Way Is Reporting That The Satellite Signal Is Degraded"
    elseif Lcase(Stcolor)="red" then
        hs
    .SetDeviceString "s55""<img src='/images/red.gif'> <font color='Red'> Satellite Down"
    hs.Speak "Direc Way Is Reporting That The Satellite Signal Is Down"
    end if
    end sub
    Try this. It's untested but should be close
    PHP Code:
    public Sub Main(sender as object)
    Dim Path as string
    Dim Pathloc
    as string
    Dim strng
    as string
    Dim Stcolor
    as string
    Path
    If
        hs
        hs
        hs
    end if
    end sub
    -Rupp
      Rupp I am getting this error and this seems to be what I keep running into.
      <TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime1 noWrap align=left>9/11/2006 9:25:53 PM </TD><TD class=LOGType1 align=left colSpan=3>Info </TD><TD class=LOGEntry1 align=left colSpan=8>Running script in background: Satellite Signal.vb</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>9/11/2006 9:25:53 PM </TD><TD class=LOGType0 align=left colSpan=3>Error </TD><TD class=LOGEntry0 align=left colSpan=8>Script compile error: Method arguments must be enclosed in parentheses.on line 25</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left> </TD><TD class=LOGType1 align=left colSpan=3> </TD><TD class=LOGEntry1 align=left colSpan=8></TD></TR></TBODY></TABLE>
      Thom
      PHP Code:
      Dim Path as string
      Dim Pathloc
      as string
      Dim strng
      as string
      Dim Stcolor
      as string
      Path
      If
      hs
      .SetDeviceString "s55""[img]http://board.homeseer.com/images/green.gif[/img] Satellite Up"
      hs
      .SetDeviceString "s55""[img]http://board.homeseer.com/images/yellow.gif[/img] Satellite Degraded"
      hs
      .SetDeviceString "s55""[img]http://board.homeseer.com/images/red.gif[/img] Satellite Down"
      end if
      end sub
      </FONT></FONT></FONT>
        Thom,
        There aren't 25 lines in the script you posted. Can you post line 25 and I'll have a look.
        -Rupp
          Rupp this is the issue I used the exact script you sent and this is the error I get
          Thom
            Oh yea. HomeSeer adds some lines to the scripts. Try this:
            Dim Path as string
            Dim Pathloc as string
            Dim strng as string
            Dim Stcolor as string
            Path="http://192.168.0.1"
            strng=hs.GetURL(Path,Pathloc,False,80)
            Stcolor=hs.stringitem (strng,2,"src=/fs/images/")
            Stcolor=hs.stringitem (Stcolor,1,".GIF")
            If Lcase(Stcolor)="green" then
            hs.SetDeviceString ("s55", " Satellite Up" )
            hs.SetDeviceString ("s55", " Satellite Degraded")
            hs.Speak ("Direc Way Is Reporting That The Satellite Signal Is Degraded")
            hs.SetDeviceString ("s55", " Satellite Down")
            hs.Speak ("Direc Way Is Reporting That The Satellite Signal Is Down" )
            end if
            end sub
            -Rupp
              PHP Code:
              Dim Path as string
              Dim Pathloc
              as string
              Dim strng
              as string
              Dim Stcolor
              as string
              Path
              If
                  hs
              .SetDeviceString ("s55""<img src='/images/green.gif'> <font color='Green'> Satellite Up"
              elseif
                  hs
              .SetDeviceString ("s55""<img src='/images/yellow.gif'> <font color='Yellow'> Satellite Degraded"
              elseif
                  hs
              .SetDeviceString ("s55""<img src='/images/red.gif'> <font color='Red'> Satellite Down")
              hs.Speak ("Direc Way Is Reporting That The Satellite Signal Is Down")
              end if
              end sub
              -Rupp
                Thanks Rupp. It seems to be working but what did you do to fix it.
                I have several small scripts to convert and do not want to become a pest
                Thom
                  I put parens around any HS call like hs.setDeviceString ("A1","tst") and also the hs.speak call
                  -Rupp
                    Rupp it seems to be working fine execpt for the icon does not show.
                    See image below
                    hs.SetDeviceString ("s55", "[img]/images/Satellite/Satellitegreen.gif[/img] Satellite Up" )
                    Thom
                      Thom,
                      I noticed the BB changed the image tags. Try grabbing what I last posted.
                      -Rupp
