Backup check script
  • Backup check script
    i've a modified version of the backup_check.txt script written by JohnWPB.
    One part of it I cannot debug to see why it's not working...
    The folder containing my backup files is c:\homeseer backup and the backup files in there are of the format -02-12-2006.zip (i.e. using the date in format dd-mm-yyyy).
    The script returns the message backup failed as it doesn't find the file created.
    This the bit that constructs the file name to check...
    sub ConstructFileName()
    'Contructs the file name to be checked
    ThisDay = day(now)
    ThisMonth = month(now)
    ThisYear = year(now)
    FullPath = dest_root
    FullPath = FullPath & "-" & ThisDay & "-" & ThisMonth & "-" & ThisYear & ".zip"
    end sub
    The rest of the script I believe is the same as the original posted. Can anyone tell me what I've done wrong?
    Malcolm
    Malcolm
    Malcolm, one way that I find helps in debugging this kind of thing is to use the hs.speak commands to tell you what you have created - in this case the 'fullpath'. I would suggest using that or the msgbox command. This might help.
      Thanks Jeff that was helpful. I had been trying to use hs.writelog but the msgbox works well.
      I've now established that the filename construct is working as it should. It's then failing at the 'does this exist' check.
      Sub DoesItExist()
      ' Checks to see if the backup file exists.
      Set fso = CreateObject("Scripting.FileSystemObject")
      If (fso.FileExists(FullPath)) = true Then
      FileCheck = True
      Set fileCreated = fso.GetFile(FullPath)
      FileDate = fileCreated.DateCreated
      end if
      if (fso.FileExists(FullPath)) = false Then
      FileCheck = False
      end if
      Set fso = nothing
      Set f = nothing
      End Sub
      I did a check and FileCheck is resolving as false. Any ideas anyone why?
      Malcolm
      Malcolm
        It looks like you have not passed the Fullpath variable to the subroutine.
        Add the Fullpath to the call i.e.
        Call DoesItExist(FullPath)
        and for the subroutine:
        Sub DoesItExist(FullPath)
        Jon
          Sorry - not sure i understand that as that part of the script is the same as the one posted in the library http://forums.homeseer.com/showthrea...ghlight=backup
          Malcolm
          Malcolm
            Sorry, I thought it was something you had added.
            You need to see if the fullpath variable is correct. Add a msgbox command as shown.
            Msgbox FullPath
            If the path is correct, change the line to read:
            Msgbox fso.FileExists(FullPath)
            See what that returns.
            Jon
              Thanks Jon - spotted the error now.
              is returning -6-12-2006.zip when the file is named -06-12-2006.zip.
              ThisDay is dropping the leading zero. Any thoughts on how to solve that? That bug must have existed in the original script too I guess?
              Malcolm
              Malcolm
                You will need to add the following then:
                If Len(ThisDay)=1 then ThisDay="0" & ThisDay
                If Len(ThisMonth)=1 then ThisMonth="0" & ThisMonth
                Jon
                  Cracked! Thank you. Owe you one again! :-)
                  Malcolm
                  Malcolm
                    good stuff!
                    Do you intend to upgrade to HS2 or stick with HS1?
                    Jon
                      I'll be upgrading to HS2 between now and 31/12/06 - whenever i get a spare afternoon! :-)
                      Malcolm
                      Malcolm
