I updated post #13
Let me know if it works
sub main()
dim index , subject , body
index = hs.MailTrigger
subject = hs.MailSubject(index)
body = hs.MailText(index)
end_hook = instr(body,"Replies to this message") -3 ' Trims off the stuff you don't want at the bottom of the email.
if end_hook < 10 then end_hook = len(body)
body = left(body,end_hook)
body = Replace (body, "Sch. Dist.", "School District",1,-1,1)
hs.WriteLog "Ridgefield School Alert" , body
'Fill in whatever actions you want
'hs.speak "Email from Ridgefield Schools:" & body
end sub
CONST cEmailAddress = "info@flashalert.net" CONST cSearchString = "Ridgefield Sch. Dist" CONST sDebug = True sub main() index = hs.MailTrigger sMailFrom = hs.MailFrom(index) sSubject = hs.MailSubject(index) sBody = hs.MailText(index) sStatus = fParseMail(sMailFrom, sBody) hs.writelog "email_parser", sStatus end sub function fParseMail(sMailFrom, sBody) if lcase(sMailFrom) = lcase(cEmailAddress) then sStart= instr(1,lcase(sBody),lcase(cSearchString)) if sStart > 0 then sEnd = instr(sStart, lcase(sBody), "replies") if sDebug then hs.writelog "info", "sStart = " & sStart if sDebug then hs.writelog "info", "sEnd = " & sEnd sData = mid(lcase(sBody),sStart , sEnd - sStart) 'sEnd - sStart if sDebug then hs.writelog "info", "sData = " & sData fParseMail = "Success" hs.speak sData else fParseMail = "Failed" end if end if
