Thanks for the script, I do however get this >> 18/12/2006 10:44:48 - Error - Running script, script run or compile error in file: Max_Uptime.txt13:Type mismatch: 'cint' in line 47 More info: Type mismatch: 'cint'
18/12/2006 14:55:42 - Error - Running script, script run or compile error in file: Max_Uptime.txt13:Type mismatch: 'cint' in line 50 More info: Type mismatch: 'cint'
No, only 2. I originally asked you to add a line of script to set the device string to 1 but found that led to another error. The error looks like it is trying to read your device string and having a problem. What is the device string right now?
Nice script - I've got it half working... the Homeseer Uptime works, but the System uptime never updates and I get this error:
Running script, script run or compile error in file: Max_Uptime.txt9:Subscript out of range: '[number: 0]' in line 47 More info: Subscript out of range: '[number: 0]'
This is the version of the text file I have just downloaded:
The Max_Time-1 you posted worked. But I didn't change the variables from the A1 and A2. As soon as I changed them to z4, z5 I got the error again. So I changed them to a81, a82 and it worked. Maybe something wrong with the variables I was picking? Well, it works, thanks for your help.
