[VBScript] Max Uptime
  • #16
    I'm using s34 and s35 - no problems for me
    • #17
      Originally posted by MeSteve
      Try the original script with the A housecodes and let me know if it works again. It will helo narrow down the error.
      It worked with the original A codes and then I tried the Z codes and it worked with them as well. Must of did something wrong on my part. But it seems to work. I'll see if it acts up, but I think it is OK.
      Thanks again.
      • #18
        Glad to here you got it working.
        • #19
          Please grab the new version as I had to fix a bug and cleaned up some code in the process.
          The bug would show incorrect incriment titles under certain situations.
          • #20
            New version posted that is VB.NET
            • #21
              I've been using the v2 script for well over a week now - it works great! - I take it this update just applies to the original version?
              • #22
                There was an update to both. Version 1 just converted to .VB. Version 2 issue was when HS restarted it just wrote the longest value to either w/ or w/o max without checking which was longer.
                • #23
                  Just to be clear (or dopey ) - I am currently running the v2 version that you posted about on December 20th... do I need to grab this latest version or not? Thanks!
                  • #24
                    Yes Steven, grab the latest as theres a bug fix.
                    TrOjAn
                    • #25
                      Cheers - have upgraded now!
