Error logs
  • Error logs
    I came across this old script and would like to us it to report errors, but I'm getting the following error:
    Error Running script, script run or compile error in file: log_errors.txt53:File not found in line 18 More info: File not found
    Bill
    Looks like the one I posted.
    The error originates here:
    Path = hs.GetAppPath & "\ah.log"
    Swap it with this:
    Path = hs.GetAppPath & "\logs\ah.log"
    ...and make sure your HS Setup looks something like the picture.
    ~Bill
      Bill,
      To save him altering his configuration, you can get this info from the settings.ini:
      LogDir=hs.GetINISetting ("Settings","gLogDir","","Settings.ini")
      If LogDir="False" then
      Path = hs.GetAppPath & "\" & hs.GetINISetting ("Settings","gLogName","","Settings.ini")
      else
      Path = hs.GetAppPath & "\Logs\" & hs.GetINISetting ("Settings","gLogName","","Settings.ini")
      end if
      Jon
        Bill
        I wrote a free plugin that monitors the log for a key word that you enter and it will email you when this word is logged. It's called LogMonitor.
        -Rupp
          Thanks guys!
          Got it.
            Thanks guys!
            Got it.
            Did you get the script working or the plugin?
            -Rupp
              The script. I will try the plugin in a few minutes and let you know.
                Yer so smart.
                Heck, you're probably the one I borrowed the code from...
                Originally posted by jon00 View Post
                Bill,
                else
                end if
                ~Bill
