Bible Verse of the Day Script
    I took the code from the "word for the day" script we discussed yesterday and found a site that does Bible Verse of the day...
    It's from an ESV (english standard version)
    VerseOfTheDay.vb
    Imports System.IO
    Imports System.Xml
    Sub Main(parm as object)
       Dim m_xmld As XmlDocument
       Dim m_node As XmlNode
       Dim CHverse as xmlNode
       dim tverse as xmlNode
       m_xmld = New XmlDocument
       m_xmld.Load("[URL]http://www.gnpcb.org/esv/share/rss2.0/daily/[/URL]")
       CHverse = m_xmld.SelectSingleNode("rss/channel/item/title")
       tverse = m_xmld.SelectSingleNode("rss/channel/item/description")
       hs.speak ("The Verse for the day is from " & CHverse.InnerText &". The Verse is. . " & tverse.InnerText)
    End Sub
    Nothing special... but thought i might save someone some legwork if i shared.
    Andrew
    Andrew B.
    Excellent Andrew. Could you please put this in the script library with the appropriate label ([VB.NET Script] )so it will be easier to find in the future?
      Problem with script.
      I have this error when running this script:
      1/27/2007 9:22:18 AM - Error - Script compile error: Type 'XmlDocument' is not defined.on line 17
      1/27/2007 9:22:18 AM - SCR - Option Strict OffImports System.IOImports System.Xmlimports Schedulerimports SystemPublic Module scriptcode2#Region "Automatically generated code, do not modify"'Automatically generated code, do not modify'Event Sources Begin <SYSTEM.CONTEXTSTATICATTRIBUTE()>Public WithEvents hs As Scheduler.hsapplication <SYSTEM.CONTEXTSTATICATTRIBUTE()>Public WithEvents hsp As scheduler.hsp <SYSTEM.CONTEXTSTATICATTRIBUTE()>Public WithEvents hssystem As scheduler.phone0'Event Sources End'End of automatically generated code#End RegionSub Main(parm as object) Dim m_xmld As XmlDocument Dim m_node As XmlNode Dim CHverse as xmlNode dim tverse as xmlNode m_xmld = New XmlDocument m_xmld.Load("http://www.gnpcb.org/esv/share/rss2.0/daily/") CHverse = m_xmld.SelectSingleNode("rss/channel/item/title") tverse = m_xmld.SelectSingleNode("rss/channel/item/description") hs.speak ("[Loc All] The Verse for the day is from " & CHverse.InnerText &". The Verse is. . " & tverse.InnerText) End SubEnd Module
      I do have the System.XML.dll add to Settings.ini as follows:
      ScriptingReferences=Classes;C:\Program Files\HomeSeer\Classes.dll;System.XML;System.XML.dll
      I don't know what I am doing wrong.
      Thanks.
      <!-- / message --><!-- sig -->__________________
      -Larry
      A member of "The HA Pioneer Group", MyWebSite
      Plugins:
      VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
      Hardware:
      Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
        Make sure your script file is named with a .vb extension.. not a .txt...
        I got errors similar when i used the wrong extension...
        Just guessing here..
        Andrew
        Andrew B.
          Larry,
          I have a suspicion that Homeseer is not reading more than one class in its scripting references entry.
          Just try:
          ScriptingReferences=System.XML;System.XML.dll
          Does it now work?
          Edit - I've just seen that your scriptingReferences is entered incorrectly.
          It should be with a comma i.e.
          ScriptingReferences=Classes;C:\Program Files\HomeSeer\Classes.dll,System.XML;System.XML.dll
          Does that work?
          Jon
            Thanks Jon, the comma did the trick. And thanks for a great script Andrew.
            Larry.
            -Larry
            Plugins:
            Hardware:
              i got the same error, i placed
              at the very end of the settings.ini, cause i didn't know where else to put it, is that the wrong spot?
              Plugins:
              BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.
                1) In Settings.ini, find the very first line which should be: [Settings]
                2) Add a new line underneath this and add: ScriptingReferences=System.XML;System.XML.dll
                3) Delete the entry that you added before.
                Jon
