This is probably just another way to skin the cat...
But i didn't see what i wanted... so i made one and thought i'd share..
Script requires Two(2) Virtual Devices
One for Pending Unread Voice Mail
One for messages that have already been heard. (Old Messages)
Script sets Device(s) ON if there are messages
Script sets Device Value(s) to number of messages
Script Sets Device String(s) to Text "# Message(s)"
That way.. you can key on status change, or value change, and also have a preformated string to indicate the number of messages in VR.
I run this every 10 minutes, and also whenever my answering machine asp page is run.
Check_Messages.txt
Andrew
Check_Messages.txt
' Routine to Check new messages in voicemail and set flag(s) ' ' Script requires Two Virtual Devices ' One for Pending Unread Voice Mail ' One for messages that have already been heard. ' ' Script sets Device ON if there are messages ' Script sets Device Value to number of messages ' Script Sets Device String to Text "# Message(s)" ' Const PENDING_VMAIL = "V82" Const OLD_VMAIL = "v83" ' Const SET_VIRT = 2 Const RESET_VIRT = 3 ' sub main() ' ' Declare Variables ' dim MsgWaiting dim unread_Count dim old_count dim ReadMessages dim unread_Text dim old_text ' ' Initialize Variables ' unread_count = 0 old_count = 0 MsgWaiting = RESET_VIRT ReadMessages = RESET_VIRT old_text = "No Messages" unread_text = "No Messages" ' ' Check All MailBoxes ' intMailBoxCount = hsp.MBCount For i = 1 To intMailBoxCount hsp.MBSort Set intMailBox = hsp.MBGet(i) ' ' Check to see if there are Unread messages ' If intMailBox.unread_messages > 0 Then MsgWaiting = SET_VIRT end if ' ' Count messages for this mailbox ' unread_count = unread_count + intMailBox.Unread_messages old_count = old_count + (intMailBox.total_messages - intMailBox.unread_messages) if old_count > 0 Then ReadMessages = SET_VIRT end if Next ' ' Set Devices ' if unread_count > 1 Then unread_text = unread_count & " Messages" elseif unread_count > 0 then unread_text = unread_count & " Message" end if if old_count > 1 Then old_text = old_count & " Messages" elseif old_count > 0 then old_text = old_count & " Message" end if hs.SetDeviceStatus PENDING_VMAIL,MsgWaiting hs.SetDeviceStatus OLD_VMAIL,ReadMessages hs.SetDeviceString PENDING_VMAIL, unread_text hs.SetDeviceString OLD_VMAIL, old_text hs.SetDeviceValue PENDING_VMAIL, unread_count hs.SetDeviceValue OLD_VMAIL, old_count end sub
