Canadian Weather
This topic is closed.
    Canadian Weather
    I was browsing the script archives and came across a Canadian weather script posted by paulrimmer in 2002. Does anyone know of this script is still working?
    I tried downloading the Canadian Weather zip file but I get nothing ,,,
    or am I doing something wrong? Never used a script before, would like to use more of them,
    Thnx
    ALfer
    Can you post a link to the script and we can have a look.
    -Rupp
      Alfer,
      Check out this link
      http://board.homeseer.com/showthread...light=canadian
      It is the updated Canadian Weather script.
      Steven
        Originally posted by karls View Post
        Alfer,
        Check out this link
        Steven
        Alfer,
        When you edit the script, locate the city information. Place a single quote in front of the 4 lines currently in use (probably Brampton or Calgary) and add the following 4 lines for Orillia.
        Const LOCATION = "Orillia"
        Const LOCATION_CODE = "on-13_metric_e.html"
        Const FORECAST_START_STRING_TAG = "Orillia:"
        Const TIMEZONE = "EDT"
        This should get you up and running.
          Canadian Weather
          Thanks Steven:
          I am not too savey with scripts but I did get this one running and it is posting "most" of the weather for Orillia.
          What I am not getting is as follows:
          W2 - No Icon in current weather.
          No Data in the following,
          W4 - Pressure
          W5 - Wind
          W8 - Visiblity
          W12 - Norm High
          W13 - Norm Mean
          W14 - Norm Low
          W15 - Yesterday High
          W16 - " Low
          W17 - " Precip
          When I go to EC website all of the data is there I just don't get it sent to me?
          I will try turning on Debug to see if that tells me anything, but I don't think I will know where to go in the script to make changes...
          Thanks again for all your help...
          ALfer
            No Debug
            I tried to turn on debug, I changed the 2 locations that I can see that I "THINK" need to be changed from true to false etc. and all I get in the log is an error msg....
            Will snoop in the script for a while longer to see if I can figure it out
            ALfer
              ALfer
              Alfer,
              Can you send me a copy of your file, I will load it at this end and check it out for you. Sorry I had missed your previous post, as I was travelling last week.
              Steven
                Steven:
                Will try to send it to you this week, I am away from home and only back on Wed then I will be in Pickle Lake for a week after Easter ...
                Will try, and thank you again for all your help ...
                ALfer
                  Canadian Weather
                  Steven:
                  Here is the script that I am using, sorry to take so long been a busy boy. Any help would be appreciated.. I am using HS ver 2.1.173
                  ALfer
                    Weather Script ???
                    Steven: I updated to HS ver 2.2.0.11 to see if it would make any difference and it did not, I still have the same problem as before ....
                    As I am not too keen on scripts I have no idea what is not working to drop some of the information from EC ....
                    Any help would be greatly appreciated
                    Thnx
                    ALfer
                      I think this script (Canadian Weather) was written by a fellow named Paul Rimmer a few years ago.
                      It kept breaking because the Canadian weather site kept changing their pages .
                      Then I think someone named Karl kind of fixed it up again but that was a while ago as well.
                      Although I don't use one at all now I found the weather xml script worked very well once it was set up.
                      I think it is on the Homeseer updater pages.
                      Good luck.....
                      Neil
                      Neil
                      Newmarket Ontario
                        Hi, I am install the script.
                        2008-01-04 10:19:37 Error Running script, script run or compile error in file: Canada_Weather.txt13:Type incompatible: 'Handler_Enabled' in line 215 More info: Type incompatible: 'Handler_Enabled'
                        This message it's send to my log.
                        My variable for my city is :
                        'Const LOCATION = "Quebec"
                        'Const LOCATION_CODE = "qc-133_metric_e.html"
                        'Const FORECAST_START_STRING_TAG = "Quebec:"
                        'Const TIMEZONE = "EST"
                        I don't understand to put this on the script ?
                          Michel,
                          I am assuming that you downloaded the latest build V2.04 from here
                          http://board.homeseer.com/showthread.php?t=107799
                          This script is now controlled from
                          http://localhost/Canadian_Weather/config.asp
                          this makes for an easier interface to adjust the parameters.
                          This config page will create an ini file located here
                          c:\Program Files\HomeSeer 2\Config\Canada_Weather.ini
                          Let me know how you make out. If you still have issues, please include the ini file.
                          Steven
                            Hi,
                            I have the same message.
                            My .ini it's include.
                            [Speech]
                            Speak=False
                            Speak_Year=False
                            Speak_City=False
                            Speak_Warning=False
                            [City]
                            Location=Quebec
                            Location_Code=qc-133
                            Forecast_String=Quebec:
                            Timezone=EST
                            [Settings]
                            Graphic_units=True
                            Debug_Flag=True
                            Debug_Note=Can_Weather
                            Handler=
                            Display_Icons=
                            Border=2
                            Marquee_Start=marquee
                            Marquee_End=/marquee
                            Display_Text=True
                            Display_Graphic=True
                            Colorize_Enabled=True
                            [Email]
                            Enable_Email=True
                            To_Email=michel@rochette.com
                            Cell_Email=Cell
                            From_Email=michel.domotique@videotron.ca
                            Email_Subject=Weather Warning
                            YAc_Enabled=False
                              Hi, i am running a second times the config.
                              The script 2.04 it's ok. The display on my log it's ok. I am install w1-w18. It's ok only a message on my log :
                              Error web server eror 404, connot serve file : c:\program files\homeseer 2\html/\envcanadaicons/chill.gif
                              I have search chill.gif. It's not found.
