This is an alternative to HomeSeer's Voicemail "Speaker Box" interface for accessing your Phone Messages.
You can:
1) Filter the mailboxes you're viewing
2) Play a message
3) Stop playing the message
4) Delete the message
5) Toggle the Read/Unread marker
UPDATES:
3/22/2007
Version 0.2
(a) Fixed date conversion bug
(b) Added ability to require mailbox passcodes be entered before showing the messages. To use this feature, create the file "PhoneMessageList-DDW.ini" in the "Homeseer 2/config" directory with the following content:
5/21/2007
Version 0.3
Added an address book lookup to find if the CID# matches anyone in your HS address book. Uses the contact name for the "From" column if it finds a match.
Discussion Here
Enjoy!
You can:
2) Play a message
UPDATES:
3/22/2007
Version 0.2
[Settings] UseMBPasscode = True
5/21/2007
Version 0.3
Discussion Here
Enjoy!
