CNN HeadLineNews Error
  • CNN HeadLineNews Error
    Just started seeing this error in the HS log after cnnheadline.txt runs.
    6/29/2007 5:58:05 PM - Error - Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidCastException: Conversion from string "" to type 'Boolean' is not valid. ---> System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToBoolean (String Value) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToBoolean (String Value) at Microsoft.VisualBasic.CompilerServices.Conversions.ToBoolean (Object Value) at scriptcode3.scriptcode3.GetIniValues(String param) at scriptcode3.scriptcode3.Main(String strMode) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
    Mark
