This is a .Net version of the AB8SS Control Script Package as posted here
Install instructions are
1. Copy ab8ss.ini file to \homeseer 2\config directory
2. Copy the 3 .vb scripts to \homeseer 2\scripts directory
3. Edit the ab8ss.ini file to set the com port, device house unit codes and names
4. Edit your startup.txt file to add
to start communications
5. Edit your shutdown.txt file to add the code of
6. Restart HS and the program will create the necessary devices and a check status event in the locations you specified in the ab8ss.ini. Note the event will be created disabled. Please enable it when you are ready to use it.
Thanks to Stevea for this excellent contribuiton.
Edited 8/29/07 - corrected a minor bug
hs.runEx "ab8ss_comm.vb","Main", "Open"
hs.runEx "ab8ss_comm.vb","Main", "Close"
