Edit (add discussion link)
Discussion here: http://board.homeseer.com/showthread...509#post787509
I took one of the scripts floating around to play "unread" voice mail and modified it a little:
Run script from any trigger (x10 palmpad, web button, etc)
Script reads through voice mail. (In Default Mailbox)
Script looks up Caller ID info for announcing "Who" left the message.
Script leaves messages "unread" in mail box.
After last message is played , script asks if you want to mark messages "read" and waits 5 seconds for response.
If the script is run Again during that 5 second window.. the messages are marked as read.
Messages are Interruptable during playback..
To interrupt messages, execute a one line script (triggered from web page, palmpad etc) with the following code
&hs.urlaction "http://localhost/hspw/?no_page_gen=1&doaction=stopspkr","GET","",""
</pre>
Script is a vb.net script Copy and paste to PlyPhoneMsg.vb
</pre>
Sub Main(ByVal parms As Object) Dim mb As Scheduler.clsMailbox Const PHLASTCALL As String = "V44" Dim MFileName As String Dim I As Integer Dim TotalVM, NewVM As Integer Dim Path As String Dim namcheck As String Dim scallername As String Dim IsRunning As String Dim retval As String IsRunning = hs.CreateVar("LRPlayMsgActive") If IsRunning = "" Then IsRunning = hs.SaveVar("LRPlayMsgActive", True) hsp.MBSort() ' Updates mailbox status & sorts VM by date. Call before MBGet... mb = hsp.MBGetDefault ' Selects the default mailbox TotalVM = mb.total_messages NewVM = mb.unread_messages Select Case NewVM Case 0 hs.Speak("You have no new messages.") hs.Speak("The last Incoming call was from " & hs.DeviceString(PHLASTCALL)) hs.SaveVar("LRPlayMsgActive", False) hs.DeleteVar("LRPlayMsgActive") Exit Sub Case 1 hs.Speak("You have one new message.") Case Else hs.Speak("You have " & NewVM & " new messages.") End Select If NewVM >= 1 Then For I = 1 To NewVM If I = 1 Then MFileName = hsp.MBFirstUnreadMessage(1, CType(mb, Object)) Else MFileName = hsp.MBNextUnreadMessage(1, CType(mb, Object)) End If namcheck = hsp.MBMessageFrom(MFileName) scallername = get_address_name(namcheck) 'namcheck = hsp.MBMessageFrom(MFileName) If scallername = "" Then scallername = hsp.MBMessageName(MFileName) End If Path = hsp.GetAppPath & "\messages\" & MFileName hs.Speak("Message Number " & I & " Recorded on " & hsp.MBMessageDate(MFileName) & " at " & hsp.MBMessageTime(MFileName) & ", From " & scallername, True) retval = hs.URLAction("http://localhost/hspw/?no_page_gen=1&doaction=playspkr&playfile=" & MFileName, "GET", "", "") hsp.MBMarkUnRead(MFileName) Next End If hs.Speak("End of new messages") hs.Speak("If you would like to mark these messages as Red, Please pres the On Button Again in the next 5 seconds", true) If hs.CreateVar("LRPlay_Waiting") <> "" Then hs.WriteLog("PlayMsg", "LrPlayWaiting already exists This really shouldn't be the case") End If hs.SaveVar("LRPlay_Waiting", True) hs.WaitSecs(5) hs.SaveVar("LRPlay_Waiting", False) hs.DeleteVar("LRPlay_Waiting") hs.SaveVar("LRPlayMsgActive", False) hs.DeleteVar("LRPlayMsgActive") Else If CType(hs.GetVar("LRPlay_Waiting"), Boolean) = True Then ' Mark messages as read hsp.MBSort() ' Updates mailbox status & sorts VM by date. Call before MBGet... mb = hsp.MBGetDefault ' Selects the default mailbox NewVM = mb.unread_messages If NewVM = 0 Then Exit Sub End If For I = 1 To NewVM If I = 1 Then MFileName = hsp.MBFirstUnreadMessage(1, CType(mb, Object)) Else MFileName = hsp.MBNextUnreadMessage(1, CType(mb, Object)) End If hsp.MBMarkRead(MFileName) Next hs.Speak("A total of " & NewVM & "Messages have been marked as read.") Else Exit Sub End If End If End Sub Function get_address_name(ByVal phone_number As String) As String Dim i_AdrCount As Integer Dim i As Integer Dim strlen As Integer Dim strlen2 As Integer Dim objContact As Scheduler.clsContact Dim s_caller_name As String Dim NamInsteadOfPhNum As String Dim TestCIDName As String NamInsteadOfPhNum = phone_number phone_number = strip_non_numerics1(phone_number) i_AdrCount = hsp.ADRCount ' number of address book entries For i = 1 To i_AdrCount ' look thru address book for number objContact = hsp.ADRGet(i) ' get the reference to the addrbk entry TestCIDName = objContact.cid_name If TestCIDName.Length >= 10 Then strlen = 10 Else strlen = TestCIDName.Length End If If NamInsteadOfPhNum.Length >= 10 Then strlen2 = 10 Else strlen2 = NamInsteadOfPhNum.Length End If If (Trim(TestCIDName.ToUpper().Substring(0, strlen)) = Trim(NamInsteadOfPhNum.ToUpper().Substring(0, strlen2)) Or strip_non_numerics(objContact.home_phone_2) = phone_number Or strip_non_numerics(objContact.home_phone) = phone_number Or strip_non_numerics(objContact.business_phone_2) = phone_number Or strip_non_numerics(objContact.business_phone) = phone_number Or strip_non_numerics(objContact.cell_phone) = phone_number Or strip_non_numerics(objContact.cell_phone_2) = phone_number Or strip_non_numerics(objContact.fax_home) = phone_number Or strip_non_numerics(objContact.fax_work) = phone_number Or strip_non_numerics(objContact.pager_phone) = phone_number) Then If objContact.First = "" And objContact.Last = "" Then If objContact.company_name = "" Then Return "" Else s_caller_name = objContact.company_name Return s_caller_name End If Else s_caller_name = objContact.First & " " & objContact.Last Return s_caller_name End If Exit Function End If Next Return "" End Function Function strip_non_numerics(ByVal what_phone_number As String) As String Dim i As Integer Dim s_char As String Dim s_new_num As String s_new_num = "" For i = 1 To what_phone_number.Length s_char = Mid(what_phone_number, i, 1) If IsNumeric(s_char) Then s_new_num = s_new_num & s_char End If Next If s_new_num.Length = 0 Then s_new_num = "*" End If Return s_new_num End Function Function strip_non_numerics1(ByVal what_phone_number As String) As String Dim i As Integer Dim s_char As String Dim s_new_num As String s_new_num = "" For i = 1 To what_phone_number.Length s_char = Mid(what_phone_number, i, 1) If IsNumeric(s_char) Then s_new_num = s_new_num & s_char End If Next If s_new_num.Length = 0 Then s_new_num = "^" End If Return s_new_num End Function
