Need Assistance with Script
    I need some assistance with this script. In addition to this script I would also like to add two zWave devices. I looked in the help file but saw no examples of how to turn on/off a zWave device in a script.
    I am trying to turn on some Christmas lights. I have a trigger at 10 min after sunset to trigger this script. At that time I want to ensure the number incount equals 2. If it equals 2 then turn on the outside Christmas Lights plus add zWave device codes Q6 & Q2
    Sub main()
    If hs.devicevalue("X8") = "2" Then
    hs.execx10 "B11","on",0
    hs.WaitSecs 5
    hs.execx10 "B13","on",0
    End If
    End Sub
    Cheers - gary
    I'm not sure how to do zwave in a script, but is there a particular reason you don't have this as an event? An event would execute even a bit quicker than a script.
      Cheers - gary
      You turn on a zwave device the same way you turn on an x10 device. I do so in most of my scripts. As an example
      hs.execX10 "Q6", "on"
      I know the execX10 is confusing because of the X10 but you should really interpret the execX10 as a "execHSDevice" instead.
      Let me know if I misunderstood your question.
      James
      Running HS 3 on Win10 .
        Thanks I did not realize I could use the same for X10 in a script for zWave.
        Now if I could only get the if statement to work
        X8 is the number in count at the house. If the value is 2 then I want to turn on the christmas lights
        I would do this in a HS Event If I knew how. I could not figure out how to do the device value or number incount which is the value of a virtual device.
        cheers
          VBscript expects strings using the quotes and integers to be just the number so your code of
          should read
          If hs.devicevalue("X8") = 2
          James
            The device value is an integer. I think all you need to do is remove the quotes around the 2.
            HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
              Thanks everyone - It now Works!!! ho ho ho
                Another confusing scripting command is hs.PlayWavFile. You would have thought this would only play wave files but it plays other media types such as MP3 etc.
                Perhaps that one should be called hs.PlayMediaFile
                Jon
