Agree with Thom completely! Great job, Steve. I notice you didn't get the DND feature on the feature list. did i not get it tested out soon enough? Gosh, the DND mode/option would be enough for me to go buy a NetCallerID box in and of itself, if i didn't already have one, that is!
Plugins:
BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.
Good catch. I forgot about the Do Not Disturb (DND) mode. I'll go back and add that to the feature list.
FYI for everyone else: Thom's and Ian's comments are not paid endorsements, but pretty close. They are two of the four guys that have been using the package for the past several months, and contributing ideas for features that eventually made it in this release.
The ZIP I posted is missing two small GIF files. Without them the call log (Callers.aspx) will not work. I'm posting them here, and will fix and repost the entire package over in the libary post tonight.
The two files go in the Images subdirectory under HTML. (the zip has the paths).
It's been so long since I had anyone doing a fresh install (rather than an upgrade) I forgot about these files. Sorry.
Update: I replaced the ZIP in the original library post (http://board.homeseer.com/showthread...088#post813088 ) with one that has the missing files (and I updated the Install instructions regarding those files).
This is obviously the first time I've tried this...
I had never encrypted source before, and I made a major blunder. Anyway, the 1.18 ZIP would never have worked for anyone. I fixed it (I think) and posted v1.18a in the other post.
No one has commented, so maybe nobody has tried it.
Anyway I *REALLY* am sorry for the mix up, but the new post should be fine.
A user found a bug in the Call Log web page (Callers.aspx). I fixed it and replaced the ZIP file in the other thread.
If anyone is using the package, you should download the new package, but all you need to replace is the Callers.aspx page. The rest is unchanged from the 1.18a ZIP.
I was wondering if an approach like this could be made to work with a standard external Data modem to get CID info into HSPhone? I assume that interfacing to the external modem would be eaiser than an internal one since the data would be available at a standard Com (or USB?) port.
I haven't ever tried a regular external voice modem (a regular data modem isn't likely to give you CID), but I had always assumed that the problem is that they each opperate a little differently: Either a different set-up string needs to be sent to them, or they report CID in a different format, or both. If you have a particular modem in mind I could take a look at it.
The NetCallerID box is ideal just because (1) it's so darn cheap (not as cheap as it used to be, but still cheap), (2) it's CID reporting is very reliable (much better than the HS Phone Modem), and (3) it's really simple to interface to and read the CIDs.
Steve
Steve,
Thanks for the reply.
I didn't realize until later that I said "Data" instead of "Voice", what I had on my mind was a Voice modem that supports Caller ID. I did not have a particuliar modem in mind, I am just trying to figure out what the possible options are. My only concern with the NetCallerID is that it appears that they are getting in shorter supply. It sounds like the HomeSeer PCI modem is going to have Vista troubles with SP1, and for me the $300 + price tag for a Way 2 Call is rather hard to swallow. What about monitoring a USB port? Is it more difficult than a conventional com port? It looks like many of the external modems are now USB. Hopefully some folks will share their ideas on this subject.
