This script will count wave files in an input directory and then randomly play one of the wave files. A wave file directory named beeps is included and contains a number of different Star Trek sounds. You could use your own sounds in different directories. I use this script to play a random wave file before HomeSeer starts speaking.
Installations:
Unzip bjd_random_wav.zip into your Homeseer 2 directory.
Setup an event in HomeSeer that executes the script: bjd_random_wav.vb("Main","\wave\beeps\")
Execute the event and listen for a random wave file to be played from the directory \HomeSeer 2\wave\beeps\
New Event Example Calling Other Wave Files:
Create other directories with different wave files and use the new directory name in the new event. For example if you create a new directory named \HomeSeer 2\wave\beeps2 and copy some wave files to it, then create a new event and executing the script as bjd_random_wav.vb("Main","\wave\beeps2\")
Files included in the bjd_random_wav.zip are:
\HomeSeer 2\Scripts\bjd_random_wavs.vb
\HomeSeer 2\Wave\beeps\ (23 wave files)
Discussion forum is found here.
Installations:
