Off Pc
    Off Pc
    Hey, I want to know if there is any script to shut down the PC. Thank you. I translate from spain with google
    Sure. You should be able to put this in a file named shutdown.bat
    rem 0 = Log Off
    rem 1 = ShutDOwn
    rem 2 = Restart
    rem 4 = Forced
    rem 8 = Poweroff
    rem You can combine these shotdown options by totaling their value. E.g. 12 = Poweroff + Forced
    C:\WINDOWS\system32\RUNDLL32.EXE shell32.dll,SHExitWindowsEx 8
    Then setup an event to run the .bat file
    -Rupp
      Thanks, but I do not understand. if you could send me the script produced.
        I posted the entire script. You can simply create a file named shutdown.bat and then cut and paste these lines into the file. Then to test it simply double click on the file. If this works then setup and event to run this file using an action of Launch Application. Put this file in your scripts folder and reference the path to the file in the event action.
        -Rupp
          rem 0 = Log Off
          rem 1 = ShutDOwn
          rem 2 = Restart
          rem 4 = Forced
          rem 8 = Poweroff
          Felipe
          Lo que tienes que hacer es copiar estas instrucciones en la section de "action" y luego ejecuta el evento.
          Hector
          Win.2003 OS, HS3
          MyTrigger,ACRF2,W800,Zwave
          AP800,Honeywell Stat
            Originally posted by Rotech View Post
            Felipe
            Stop that Hector.
            -Rupp
              Why, is that rupp, aim just trying to help. Cant you see he has problem trying to understand, whats wrong speaking in another language?
              Hector
              Win.2003 OS, HS3
                It was a joke.
                -Rupp
                  You missed the little smiley face at the end denoting humor.
                  Marty
                  XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
                  Playing with HS3 a bit but it's just play at this point.
                    Maybe the smiley face means something different in Spanish
                    I think it is great that some people speak more than one language, me I am totally "single tongued"
                    Over The Hill
                    What Hill?
                    Where?
                    When?
                    I Don't Remember Any Hill
                    Virtualized Server 2k3 Ent X86 Guest on VMWare ESXi 4.1 with 3 SunRay thin clients as access points - HSPro 2.4.0.48 - ZTroller - ACRF2 (3 WGL 800's) - iAutomate RFID - Ledam - MLHSPlugin - Ultra1wire - RainRelay8 - TI103 - Ultramon - WAF-AB8SS - jvESS (11 zones) - Bitwise Controls BC4 - with 745 Total Devices - 550 Events - 104 scripts - 78 ZWave devices - 42 X10 devices - 76 DS10a's 3 RFXSenors and 32 Motion Sensors
                      I wasn't smiling to put one on.....
                      Hector
                      Win.2003 OS, HS3
