I have created a plug-in for the Ademco (Honeywell) Vista series of security panels when used in conjunction with the Vista ICM.
The current version is 1.0.1.1. The latest version can always be found here: http://www.shadowguild.com/vistaicm/...icm_latest.zip. (Well, when the server isn't down for maintenance.
I have not created a nice installation yet, as it's really just one file copy. I may update that at a later point.
Private Message me if you have any questions.
Pre-Requesites
Installation
Pre-Requesites
- The plug-in is using methods in HomeSeer that require version 2.2.x.x or higher.
- Only one ICM can be in use in the network at a time (this includes Vista ICM as well as other ICMs). Although, an ICM other than ffice:smarttags" /><ST1
lace w:st="on">Vista</ST1
lace> is possible, it has not been tested, so no guarantees.
- Stop HomeSeer 2
- Copy the hspi_vista_icm.dll file to the HomeSeer program directory.
- Run HomeSeer 2
- Go to the Setup menu for the interfaces and Enable the Vista ICM plug-in (no configuration necessary at this point), but may be performed through the plug-in pages (Config).
