[VB.NET] MCE Control Script
    Enclosed is a small script that will allow commands to be sent to your MCE computer via Homeseer events. It makes use of a freeware application called the 'MCE Controller' from Source Forge. I've included the install package in the ZIP, but if you are paranoid you can find it via Google.
    The package includes a script, the MCE Controller setup, a sample config file, and step-by-step instructions.
    Please don't post questions or comments in this thread. Rather, use either the MCE sub-forum (http://board.homeseer.com/forumdisplay.php?f=657) or the Script and Plug-in Discussion sub-forum (http://board.homeseer.com/forumdisplay.php?f=633).
    Steve
    v1.1
    Well, I really thought this was such a simple little thing that no one would find something more to do, but... Turns out some users have MCE running on many machines on their network, so a request came in to modify it to support communicating with multiple instances of the MCE Controller.
    First off: This new version is backwards compatible with the previous one, so everything you have set up to talk to one MCE Controller shold not need to be changed. On the other hand, if you don't have more than one MCE machine, you don't need this update anyway.
    The ZIP here contains the new script, the original sample INI file, the same instructions file from the original ZIP, and a new set of instructions (augmenting the original, not replacing it) for using the package for multiple MCE Controllers.
    I didn't include the MCE Controller install package in this ZIP. It's in the original (at the top of this thread) or you can find it on Source Forge.
    Steve
