Window shade script/plugin?
    Is anyone aware of a script/plugin that handles Extended X10 data for the ZAX window shade controllers from Xanura?
    See this thread for details: http://board.homeseer.com/showpost.p...9&postcount=11
    Best regards,
    -Mark-
    If you're not out on the edge, you're taking up too much room!
    Interested in 3D maps? Check out my company site: Solid Terrain Modeling
    stefxx
      Thanks a lot for sharing. I'll run some tests this weekend, and let you know if it works with the CM11 controller as well.
      HS3 Pro Edition 3.0.0.548| Plug-Ins Enabled: Sonos 3.1.0.57, RFXCOM 30.0.0.45, X10 3.0.0.62, IPThermostat 3.4.5.0, Pushover 3P 0.0.0.54, Blue-Iris 3.1.3.33206, Z-Wave 3.0.10.0, BLML2HS 2.0.28.0, mcsMQTT 6.12.4.0, Insteon 3.0.7.19​​ | Win 7 32-bit | Intel Atom D2550 @ 1.86GHz 4GB RAM
        It works with a Xanura PMIX35 or CTX35, or an original ACT TI103. Just make sure you use the latest version 2.0.5. Previous versions don't report all extended data back.
        I have no experience with a CM11, but as long as it reports all extended data (and the driver too) you should be fine.
        stefxx
