Script Help.
    Script Help.
    Hello.
    I have a simple trigger that sends
    &hs.RunEx "Pioneer.txt", "SendCommand", "VU"
    to my Pioneer Receiver.
    I would like the command sent to be different based on the status of a device. In non script speak this would be...
    If device&1 = "Power Off"
    then send "&hs.RunEx "Pioneer.txt", "SendCommand", "VU""
    else send "&hs.RunEx "Pioneer.txt", "SendCommand", "ZU""
    Could someone help me translate this into vb?
    Jon
    Off the top of my head and untested
    sub main()
    if hs.deviceStatus("&1") = 3 then
       hs.runEx ("Pioneer.txt", "SendCommand", "VU")
    else
       hs.runEx ("Pioneer.txt", "SendCommand", "ZU")
    end if
    end sub
    remember that the syntax for runEx is : hs.RunEx("test.txt","launch_app","notepad.exe")
    so is vu and executable?
    put this in a file with a .txt extention and test
    -Rupp
      Thanks Rupp - I understand all of that apart from the
      What does the 3 represent and how does this relate to "Power Off"
      (VU by the way is the RS232 command that the script sends to the receiver on COM - representing 'Volume Up')
      Jon
        Jon,
        Device status stores the status like this.
        2 = ON
        3 = OFF
        4 = DIM
        17 = UNKNOWN
        I "assumed" the device was off so thus the line. Is the device not off?
        -Rupp
          Ah - I understand. The Device is the Russound plugin ZONE device. I will try this tonight and see if 3 works. More generically, if the status is "Power Off" can I use this as
          hs.deviceStatus("&1") = "Power Off"
          or is it more complicated than that.
          Also, I've looked about on the board, but didn't see anything - is there a 'beginners guide to VB' for homeseer, or any other reference that would help me with the syntax? I can program a bit of Basic and Applescript, but don't have reference for VBscript
          Jon
            If what you see is Power Off and there is no html included in the deviceString then you can use if hs.deviceString("&1") = "Power Off"
            To test to see what is actually stored in the deviceString you can use this in the immidiate window to test.
            &msgbox(hs.deviceString("&1"))
            This will pop up a messagebox on your HS server so make sure you only test it locally. It will show the exact string.
            -Rupp
              Great - thanks for the guidance
              Jon
                You're welcome. Let us know what shows and we can get you going on this.
                -Rupp
                  Hi Rupp,
                  Ok, some success. I had to remove the () on line 3 and line 5 and then the script would process. However, I was getting ZU when I expected VU, so I tried the &msgbox command and got "Power Off", so I changed the if to use "Power Off", but I still got ZU.
                  So, rather than using the &1 device (my Russound Zone), I switched to _35 which is a simple on off light. Using this device, the script works properly.
                  So, my only remaining issue now is how to read my &1 device. I attach a screenshot of what I see - but 3 and "Power Off" haven't worked for me.
                  Any suggestions?
                  Jon
                    You need to do an &msgbox(hs.deviceString "&1") and post what shows.
                    -Rupp
                      I did that and it shows Power Off
                        Try this:
                        sub main()
                        if ucase(hs.deviceString("&1")) = "POWER OFF" then
                        else
                        end if
                        end sub
                        -Rupp
                          Try this:
                          sub main()
                          else
                          end if
                          end sub
                          Nope - still get ZU.
                          Sorry about this - its an odd one - I know the script is ok because it works on a light.
                          Do you think there is something peculiar about the Russound status?
                          Jon
                            Try this.
                            &msgbox("+++" & hs.deviceString "&1" & "+++") and post a screen shot of the messagebox
                            -Rupp
                              Did you see this addition?
                              -Rupp
