Script Help.
    #16
    Hi Rupp - yes I did thanks - I need to be at home as for some reason the VNC client won't let me logon from work. As soon as I get in I will post the results. Thanks for the follow up
    Jon
      #17
      Hi - I managed to get on - when I run that script I get an error
      Running script, init error: Expected ')'
      I tried a few options moving the () and removing the & but I get the same thing.
      Jon
        #18
        Sorry, This should work.
        &msgbox("+++" & hs.deviceString ("&1") & "+++")
        -Rupp
          #19
          Hi Rupp,
          This is the result
          Jon
            #20
            I'm totally confused. The code in post #13 should work then.
            -Rupp
              #21
              Ok thanks. I will approach it again this evening and see if I can determine why it isn't.
              Thanks for your support
              Jon
                #22
                Rupp,
                I have a solution, but its doesn't explain the Russound device oddness.
                I have added a virtual device that changes to On or Off based on the Russound being turned on or off. I then base my script on the status of this device rather than the Russound. It works, so I'm happy, but I wish I knew why the Russound device didn't work directly.
                Thanks for all you help. I am learning fast thanks to your input
                Jon
                  #23
                  Yes that is an odd one. There has to be something else in that deviceString to prevent the matching.
                  -Rupp
