Hello,
is there a way to poll the speaker instances to see if vr is listening for commands or not?
I was hoping for a way to make a virtual device to monitor this parameter and trigger an event to call a random phrase and mute the tv when vr starts listening.
Is this possible?
I use this script in an event called VR Off to shut down VR.
sub main ()
hs speak. hs plugin("ROC-Rnd") .random("VR off")
hs ListenForCommands FALSE
end sub
This wont work in reverse because speaker is not listening until after the voice command, speaker would have to have the option to run a script when it speaks (or instead of speaking) the attention acknowledge phrase.
I'm trying to work around this limitation with no success at this point.
Anyone have any ideas?
Is this possible?
sub main ()
end sub
