I used Rspeak 1.01 for quite a while successfully. It simply stopped working. I cannot locate the exe anywhere in the archive. Has anyone got a newer version?
Rspeak is an exe that works with MS Agent. It still loads into memory, but is not accessible from the tray or Agent. I think an XP update might have messed it up.
The last post I can find about it is below and described as:
"This a a re-post of an HS script by Martin Neville called RSpeak.
It allows HS to speak on other computers connected by a LAN, Intranet or even over the Internet (If HS is on a server) It requires Microsoft's Agent. (may work with others, never tried it." - Gogs
