Need script help
  • #46
    Here is the complete code snippet. The Script will add a virtual device called “TapeDrive” when it runs for the first time. The script will also assign the a value to it. You have to schedule this script to run. Let me know if this works for you. Make sure the path I have is correct...
    Sub Main()
    Dim N
    Dim MyTape
    Dim Results
    Dim Cap
    Dim dvRef
    set objShell= CreateObject("WScript.Shell")
    Set objExecObject = objShell.Exec("C:\Progra~1\nsr\bin\nsrmm") 'full path of the nsrmm
    Do Until objExecObject.StdOut.AtEndOfStream
    Results = Results & objExecObject.StdOut.Readline()
    Loop
    hs.WriteLog "Debug", Results
    N = split(Trim(Results)," ")
    Set objExecObject = objShell.Exec("C:\Progra~1\nsr\bin\mminfo.exe -a -r written,%used " & N(3)) 'full path of the nsrmm
    Cap = Cap & objExecObject.StdOut.Readline()
    Loop
    N = split(Trim(Cap),"(%)")
    dvRef = hs.GetDeviceRefByName("TapeDrive" )
    if dvRef = -1 then
    set dv = hs.NewDeviceEx("TapeDrive" )
    dv.hc = "z"
    dv.dc = "15" 'change this if this code is already taken
    dv.dev_type_string ="Virtual"
    end if
    hs.SetDeviceStringByName "TapeDrive",N(1),true
    hs.WriteLog "Debug", Cap
    Set objShell = Nothing
    End Sub
    • #47
      SSK.... This is perfect!!! Thank you very much.
      I really appreciated you taking the time to help me out.
      Modified it slightly to give me
      Tape Usage: 5322 MB 13% (Written/Used)
      Happy Thanks Giving!
      Robert
