Warning: This script will overwrite your existing 'check_vcmd.txt' file if it already exists. So backup or rename this file if you are already doing something with it.
The Moody Computer Discussion
This script will not only give multiple responses to the attention/ignore phrase it will
determine if your computer is in a good mood or bad mood. You will never know if you will be dealing with a pleasant helpful assistant, or an irritated, complaining assitant. If in a bad mood, HS will complain about having to do all those chores and not feeling appreciated.
The setup information can be found in the discussion or in the complain.setup.txt file.
Version 0.01
Enjoy!
Danny Norris
Version 0.01
Enjoy!
Danny Norris
