The attached script will update your domain name (created with DynDns.org) with your currect IP address. It also supports wildcards and MX records.
Notes:
Run the script once "out of the box" and then modify the INI file in the config directory
Use can update multiple hosts (as long as they are the same System type) by seperating them by commas in the Hostname section
Version 2.0 -
* Added No-IP.com updating
* Added the ability to enable/disable DynDNS updating
* Fixed timeout between updates (I never accounted for the Hour or day)
* Added the ability to have 2 DynDNS accounts
Version 2.1 -
* Fixed small bug - not enough ')'
Version 2.2 -
* Fixed Bug: If using only No-IP, last update time never updated
Version 2.3 -
* No-IP.Com changed the way they do updates, so I did too.
Version 2.4 -
* More error checking on detected address
Discussion can be found Here
---rah!
[This message was edited by RAH on Sun, 13 July 2003 at 05:05 PM.]
Notes:
Version 2.0 -
Version 2.1 -
Version 2.2 -
Version 2.3 -
Version 2.4 -
---rah!
