# Script Name: Redirect.pl
# Purpose:
# Many cable and DSL companies don't provide a static IP address with their
# service. Instead, customers get a dynamic IP address which changes every so
# often. Typically, a service provider also give some amount of "free"
# web space.
# This script is intended to obtain the current IP address of your
# firewall/router, create an HTML redirect page, and to FTP the redirect
# page to your "free" web space. Users who hit your redirect page, will
# be redirected to your home web server (like homeseer). Note: You will
# have to set up your firewall/router appropriately for this.
# Also, this script assumes it is being run from homeseer as it uses a
# couple of $hs variables.
# This script was tested using Active State's Active Perl 5.8.
# Installation Instructions:
# 1) Make sure perl is installed on your computer.
# 2) Place this script in the homeseer/script folder.
# 3) Change the necessary variables below. See "SET THESE VARIABLES
# BEFORE USE".
# 4) Create an event in homeseer to automatically run this script periodically.
sub main()
require LWP::UserAgent;
use NET::FTP;
use OLE;
# SET THESE VARIABLES BEFORE USE. #
# Set the Homeseer Web port number. 80 is the default.
$port = "80";
# Set the username and password for the LOCAL web server.
# Typically this will be guest:guest.
$userpass = "guest:guest";
# Set the name of the redirect file you want to be posted on your external
# web space.
$redirect = "redirect.htm";
# Specify the name of the FTP/Web server that you want the redirect
# page sent to.
$ftpserver = "upload.comcast.net";
# Specify the username and password of the FTP server.
$ftpusername = "XXXXX";
$ftppassword = "xxxxx";
# DONE setting variables. #
# Get the path name and new file name.
$p = $hs->GetAppPath();
$Folder = CreateObject OLE ("Scripting.FileSystemObject");
$TextStream = $Folder->CreateTextFile("$p\\scripts\\$redirect", True);
# Obtain the IP address of my router.
use HTTP::Request::Common;
$ua = LWP::UserAgent->new;
$resp = $ua->request(GET 'http://www.showmyip.com/simple/');
# Tweek the result so that we only get the IP address itself.
$result = $resp->content;
$id = index($result," ");
$ip = substr($result,0,$id);
$template = "<\!DOCTYPE html PUBLIC \"-\/\/W3C\/\/DTD HTML 4.01 Transitional\/\/EN\">\n" .
"<html>\n" .
"<head>\n" .
"<meta http-equiv=\"content-type\"\n" .
"content=\"text\/html; charset=ISO-8859-1\">\n" .
"<meta http-equiv=\"Refresh\" \n" .
"content=\"1; URL=http:\/\/$userpass\@$ip:$port\"> \n" .
"<title>Redirect Page<\/title>\n" .
"<\/head>\n" .
"<body>\n" .
"<br>\n" .
"<\/body>\n" .
"<\/html>";
# Write the contents to the output file.
$TextStream->Write($template);
# Close up the template, and the resulting file.
$TextStream->Close();
# FTP the new file to the web server.
$ftp = Net::FTP->new($ftpserver, Debug => 0);
$ftp->login($ftpusername,$ftppassword);
$ftp->put("$p\\scripts\\$redirect",$redirect);
$ftp->quit;
# Write to the log.
$hs->writelog("Info","Updated Redirect Page.");
http://mywebpages.comcast.net/verjinski
[This message was edited by RichV on Mon, 19 January 2004 at 08:33 PM.]
# Purpose:
# web space.
# BEFORE USE".
sub main()
use NET::FTP;
use OLE;
$port = "80";
# web space.
# page sent to.
"<html>\n" .
"<head>\n" .
"<\/head>\n" .
"<body>\n" .
"<br>\n" .
"<\/body>\n" .
"<\/html>";
$ftp->quit;
# Write to the log.
