[ASP]{Script] HS Updates & Release Notes Package
    [ASP]HS Update News and Release Notes
    Kevin (kev_t)
    Discussion Topic is here
    http://ubb.homeseer.com/6/ubb.x?a=tp...955#9566029955
    Version details
    v1.0 1 feb 2004
    v1.0.2 feb 2004 modified to ftp the notices from the Homeseer FTP site
    and extract he required file from the zip
    Summary
    The Updates News and Release Notes For Homeseer and Homeseer Phone are
    not readily available from the HS Web server
    (They are available I think as part of some of the Updater Web Pages and
    also from the Homeseer GUI on the server itself but only update when the
    updater is run)
    This set of ASP's allows the update news and release notes to be
    available either in total or in sections inside the homeser Web
    interface as follows:
    <UL TYPE=SQUARE>
    Asp name - Wrapper ASP - Processing ASP
    Whole Release Notes - release_notes.asp - rel_note.asp
    Homeseer News - update_news.asp - u_news.asp
    Homseer Release Notes - release_notes_HS.asp - rel_note_hs.asp
    Homeseer News & Release Notes - news_rel_notes.asp - n_rnote.asp
    Homeseer Phone Release Notes - release_notes_HSP.asp - rel_note_hsp.asp[/list]
    The one I wanted in particular was the Homeseer News and Release notes,
    ie excluding HSPhone, which I don't have.
    (Roughly) How it works
    notices.zip is downloaded from the HST ftp site (Thanks Joe) and
    unzipped by the script Get_Notices.txt
    This script needs an event creating which runs once a day, probably
    early in the morning
    When you call one of the Wrapper ASP's, it calls the relevant processing
    ASP.
    The processing ASP's parse the file notices.htm which is located in the
    \Homeseer\Updates directory to produce the desired result
    Credit Where credit is due
    Get_Notices.txt uses a dll to unzip notices.htm from the downloaded
    file. This dll is sourced from
    http://www.aspheute.com/artikel/20001113.htm and is included in my zip
    I used a couple of snippets from Jeff Farmers Updater script as my
    starting point
    These ASP's are dependant on Jeff Farmers Includes package which is
    available from the Updater
    Installation
    To install, unzip the files above into the \Homeseer\HTML directory and
    the Gifs into the \Homeseer\html\images directory. the dll goes into the
    homeseer directory.
    The dll must be registered, eg for windows 98 :-
    regsvr32 c:\progra~1\homeseer\zipcom.dll
    Your system may be different
    Use
    Choose one (or more) of the pages from the list above and add them to
    your links.htm or menu system. Alternatively you can get them directly
    by typing the wrapper asp name into the address bar, eg
    http://homeseer_server/update_news.asp
    General Notes
    Note 1
    The parsing of the script depends on HST not changing the colours (Note
    UK English spelling!) it uses in notices.htm
    Note 2
    HST supply a zip10.dll with the updater, but I have been unable to get
    it to work from a script. If anyone can tell me how, I would prefer to
    use that instead
    Enjoy
    Kevin
    [This message was edited by kev_t on Wed, 04 February 2004 at 07:28 AM.]
