VR_TelephoneDial
9/15/2004 V1.0 by Scott Bessel
What it does
It will find any phone number in your WAF-NetCallerID-Phone-List.txt file
based upon the caller name in that file and the code ending in a '1'
I.E.
<pre class="ip-ubbcode-code-pre">
916-555-6930 2001 Anthonys Car Stereo
916-555-0173 2000 Folsom Lake Dodge
209-555-7339 2001 Mariposa Coffee Company
877-555-6737 5000 American Express Sales
858-555-4400 2000 Wstrn Radio Ele
209-555-7339 2001 Scott's Office
877-555-6737 1001 Scott's Cell Phone
858-555-4400 1001 scott's home phone
</pre>
Only Anthony's Car Stereo,Mariposa Coffee and all of Scott's numbers will be available through this command.
the system uses the first word in the name as a voice command and the rest as optional.
So Saying "Anthonys", "Anthonys Car", "Anthonys Stereo" will all return Anthonys Car Stereo.
Saying "Scott's" will let you select which number you wish, if the selection is too long you can say 'Cancel' instead of yes/no to all the names and the system will exit
You can also say "Scott's Cell" to get the cell number directly. You cannot just say "cell phone" and get everyone's cell phone
Requirements:
HSP Build 182 or greater (found here: ftp://ftp.homeseer.com/updates/hsp183.zip)
earlier builds block outbound dialing which prevents the dial section from working
An event that calls this script with a voice command.
This has only been tested on a Way2Call unit, but 'should' work on the HSP modem
This reads your phone list from the WAF-NetCallerID-Phone-List.txt that is created by WAFNetCallerID on any new caller
Installation:
Copy this script to your \scripts directory
create an event, manual trigger with a voice command
the voice command string is "Telephone (Find|Dial)"
make the voice command phone only.
Usage
Say "Telephone Find"
the system will ask for the name
if found it will ask if correct, then speak the number
it will ask if you want the number repeated
it will then ask if you want the number dialed
Say "Telephone Dial"
If you have any issues or questions at all please feel free to contact me. Either on the HS forum or by email directly
Scott Bessel (sbessel@comcast.net)
****UPDATED****
9/16/2004 v1.1
fixed a bug where hsp.linedial would not log the outbound call to the callers.log.
I hard coded it to log the calls, this keeps my outbound caller log web page correct.
I also opend a ticket for the HSP guys to fix it.
9/22/2004 v1.2
removed the second "do you wish me to dial it" from the Dial portion
9/24/2004 v1.3
added hangup detection, found if you hungup on the script waiting fro a vr answer it would stay running and when run the second time would put you right back where you left off, completly confusing the VR engine.
What it does
I.E.
</pre>
Requirements:
Installation:
Usage
****UPDATED****
9/16/2004 v1.1
9/22/2004 v1.2
9/24/2004 v1.3
