This is my version 1.4 of Snevl_bb, a script-based Homeseer control package for the BetaBrite LED sign, as well as other LED signs from Adaptive Micro systems (I have it running on a BetaBrite and a 2-line 4120C, and it has been tested on the larger 4200C). Like the other stuff I do, this is completely free to other Homeseer users.
Features:
I've provided pretty extensive documentation to get you going (attached separately here if you want to look at the docs before you download the package).
My thanks to Thom Hinton (GreenAcres) for not only keeping up the pressure on me to do this once he found out I had my own BetaBrite script, but also for his beta testing so far.
As with SnevlCID, I will make every effort to support anyone using this. Please post any comments, bugs, or requests in the discussion thread, here: http://board.homeseer.com/showthread...618#post907618
Thanks for giving it a look!
Steve
Features:
- Support for up to four signs, each with its own messages under HS script / event control.
- A configuration editor web page for set up and configuration changes.
- User defined combinations of separate message buffers and string variables, allocating any or all of the available sign memory to various buffers per user settings.
- Access (via embedded formatting commands) to all the colors, transitions, special characters, speeds, and fonts that the sign supports. You simply embed these formatting commands into your message text.
- Insertion into messages (again with formatting commands) of string variables, date (several formats supported), and time.
- Basic control functions, such as turning a sign on/off, setting the clock, or changing what messages that you have already stored are currently displayed.
- A customized VB.NET version of the CNN Headlines script, this one displaying a ticker-tape-like display of the headlines.
- A script that ties into the CNN Breaking News script (I posted a new version in the script library a while back) to interrupt the normal sign display with the text of the breaking news item, then restore the normal display.
- An "Important Dates" script that allows you to include upcoming birthdays, anniversaries, and holidays on your sign display. A web-based editor for your own important dates is also included.
- Some examples of using a two-line sign, where you can specify what you want on each line.
- A Music add-on to display the current artist and track title on the sign when music is playing, blank that part out when music stops, and update it when the track changes.
- A sample web page to send stuff to the sign, and lets you define colors, transitions, and display times. Mostly useful to let you see how the various transitions work, so you can choose how to use them in your events / scripts.
- A script to display caller ID of a call coming in from SnevlCID (you *KNEW* I had to tie this to my own CallerID application!).
Steve
