I'm trying to use the script in post four here:
http://board.homeseer.com/showthread.php?t=128127
It gives me an error on Line 10, which is the first line of code, that it expected ")".
It is rather annoying that I can't even get past the first line of code during my troubleshooting.
I'm using a USB-UIRT for an IR Match to trigger an event for my Z-wave adapter to dim or brighten by 10% for each button press. I'll have a code for Dim and a code for Bright mapped on my remote for each light. I'm sending the following optional parameters ("Main","-10/Q6") with the dim_bright.txt script. The light I'm testing is Q6.
I'm new to Homeseer scripting so any help would be appreciated.
' adjust light level up/down 10% based on input parameter ' string containing dim/bright value and device code ' Thanks to initial script from huggy_d1 (2008/04/28) ' Modified by CheeryFool (2008/05/12) to use two concatenated event ' input parameters (relative dim value and device code), which are ' parsed into variables. Sub Main(ByVal inputparms as String) dim pos = InStr(inputparms, "/") dim strSize = Len(inputparms) dim valchg as String = Left(inputparms, pos - 1) dim varLight as String = Right(inputparms, strSize - pos) dim debugmode as Boolean = vbFalse dim lDimLevel as Long '---device status code '0 = All Units Off '2 = ON '3 = OFF '4 = DIM 'store current dim level lDimLevel = hs.DeviceValue(varLight) 'if debug mode ouput current values to log if debugmode then hs.writelog( "Harmony Lights", varLight & " Dim Level = " & lDimLevel ) if debugmode then hs.writelog( "Harmony Lights", varLight & " Device Status = " & hs.DeviceStatus(varLight) ) if debugmode then hs.writelog( "Harmony Lights", varLight & " Device Value = " & hs.DeviceValue(varLight) ) 'max out new dim level at 100% and set to ON if lDimLevel + valchg > 100 then lDimLevel = 100 hs.ExecX10( varLight,"On",,,vbTrue ) hs.SetDeviceStatus( varLight, 2 ) hs.SetDeviceValue( varLight, lDimLevel) 'min out new dim level at 0% and set to OFF elseif lDimLevel + valchg < 0 then lDimLevel = 0 hs.ExecX10( varLight,"Off",,,vbTrue ) hs.SetDeviceStatus( varLight, 3 ) hs.SetDeviceValue( varLight, lDimLevel) 'else set new dim level, device value and device status else lDimLevel = lDimLevel + valchg hs.ExecX10( varLight,"DDim", lDimLevel,,vbTrue ) hs.SetDeviceStatus( varLight, 4 ) hs.SetDeviceValue( varLight, lDimLevel) end if 'if debug mode output end values to log if debugmode then hs.writelog( "Harmony Lights", varLight & " Dim Level = " & lDimLevel ) if debugmode then hs.writelog( "Harmony Lights", varLight & " Device Status = " & hs.DeviceStatus(varLight) ) if debugmode then hs.writelog( "Harmony Lights", varLight & " Device Value = " & hs.DeviceValue(varLight) ) end sub
