Flash Lamps with restore
You need to use devicestatus not devicevalue. This should get you going but assumes you do not use dimming:
PHP Code:Sub Main()
dim v
v=hs.Devicestatus ("A2")
hs.writelog "initial state of lamps", v
hs.execx10 "A2","on"
hs.execx10 "A2","off"
If v=2 then
hs.ExecX10 "A2", "on"
hs.writelog "final set lamps to on"
else
hs.ExecX10 "A2", "off"
hs.writelog "final set lamps to off"
end if
End Sub
To show code in the blue box, highlight the text you want and then press the php button:. You will see it when you reply.
Try the following:
PHP Code:Sub Main()
dim v,x
x=hs.devicevalue ("A2")
If v=2 then
elseif V=3 then
elseif V=4 then
hs.ExecX10 "D3", "DDim", x
hs.writelog "final set lamps to dim value " & x
else
hs.writelog "lamp status is unknown"
end if
End Sub
Please note that X10 is very bad for flashing lights due to it's transmission method.
I've made a few tweeks, mainly arround log entries so i can see what's going on. And changed lamp moduelto teh office desk light so I don't have to go downstairs to see results! However the final dimmed state doesn't get set even though according to the log the value is correct
PHP Code:Sub Main()
dim v,x
v=hs.Devicestatus ("A16")
x=hs.devicevalue ("A16")
hs.writelog "initial dim value of lamps", x
hs.execx10 "A16","off"
hs.execx10 "A16","on"
If v=2 then
hs.ExecX10 "A16", "on"
hs.writelog "final set lamps to on", v
elseif v=3 then
hs.ExecX10 "A16", "off"
hs.writelog "final set lamps to off", v
elseif v=4 then
hs.ExecX10 "A16", "DDim", x, 0
hs.writelog "final set lamps to dim value " , x
else
end if
End Sub
PHP Code:20/06/2010 11:17:33 final set lamps to dim value 30
20/06/2010 11:17:33 X-10 Command sent to Office Desk Light: A16 DDim Dimval: 30 Data: 0
20/06/2010 11:17:33 X-10 Command sent to Office Desk Light: A16 off Dimval: 0 Data: 0
20/06/2010 11:17:33 X-10 Command sent to Office Desk Light: A16 on Dimval: 0 Data: 0
20/06/2010 11:17:33 initial dim value of lamps 30
20/06/2010 11:17:33 initial state of lamps 4
20/06/2010 11:17:33 Event Running script in background: Flash Lights with restore
20/06/2010 11:17:16 Device Control Device: Office Desk Light (A16) Dim by 70%
It may be due to the sheer number of X10 signals being sent. I've added a delay between X10 commands.
Try this:
PHP Code:Sub Main()
dim v,x
hs.waitsecs 2
hs.waitsecs 2
hs.waitsecs 2
hs.waitsecs 2
hs.waitsecs 2
If v=2 then
elseif v=3 then
elseif v=4 then
else
end if
End sub
