BACK UP YOUR addressbook.xml BEFORE RUNNING THIS JUST IN CASE...
This script will take the phone numbers in your address book and save them all as 1-503-555-1212 format. You can tweak the script if you want it saved other ways.
When you run it all of the changed numbers will be in the HS2 logfile.
The second time you run it the script will basically check all the numbers actually changed to the new format.
I know the script can be written better but I was having problems with the Function command so I did the copy/paste route.
