I have a device that tells me what the phase is. new, full, Waning Gibbous, Third Quarter etc, there are 8 phases that I use and have a graphic for.
I have an event that I run as a recurring event that runs the script that changes the graphic in HSTouch.
Since it's a recurring event it runs far more than it has to considering the device changes only 8 times a month, but it does work.
What I was wondering was would I be able to use this plug-in to track that moon phase device string and only run the event when it changed? Sort of like a conditional trigger.
like if device changed to
new
or
full
or
the other 6
run the script.
I would think that if there were a trigger for ANY change in a specific device that would also work and run the script.
Even if not I can see possibilities for this, like I said in the other thread, you can't have enough triggers.
Marty
XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
Playing with HS3 a bit but it's just play at this point.
You would indeed need 8 triggers, or use 1 trigger ('match (like)' and use '*' as the pattern) to trigger a script which can analyze the device string when executed.
I'm all about adding more trigger types, so if you can think of one that would make life easier, let me know.
Thanks, I'll give that a try and let you know.
Marty
I tried using the '*' to stimulate any change in device string. The moon phase changed overnight but alas the trigger did not fire. Maybe just a trigger for any change would work better?
Marty
I just tested this myself, and it does work, so maybe there is something else going on here. What does the string look like? Did you select the 'match (like)' trigger?
Hmmm, I thought I had it right but i've been wrong before. I did not have verbose on but since it didn't run maybe nothing would have shown anyway. I'm turning it on now just to see if anything shows up. When I turned it on I see this in the log to start.
INFO DeviceString = Waxing Gibbous - DeviceValue = 0
the event I set up looks like below.
Marty
After a few minutes of verbose logging the log filled up with lots of entries that are not even my.trigger devices. I've turned off verbose logging for now, it made my log un-readable, ouch.
Marty
Looks like you added quotes, which is why it didn't match. I should have mentioned not to use those quotes (so only use * as the pattern), my bad. Verbose logging does dump a lot of info, but it allows me to troubleshoot these things remotely. I'll be adding the Any trigger soon.
See, somehow I just knew it was me. I'll remove the quotes and see how it goes. Thanks for straightening me out!
Marty
Well... now that I have it set right it seems to work like a charm. No real need to add an ANY trigger since this seems to do the same thing.
Thanks again for the clarification.
Marty
