Since few months i have some error's in HS log.
When the error is there i will see more than 50 error line as in example.
The problem is that I can't find the script..
When running all the events and actions before the error it will not result again in the same error.
looks like it's random.
Ho can i trace this error?
28-9-2010 18:58:26 Error Running script, init error: Syntax error 28-9-2010 18:58:24 Error Running script, init error: Syntax error 28-9-2010 18:58:24 Error Running script, init error: Syntax error 28-9-2010 18:58:22 Error Running script, init error: Syntax error 28-9-2010 18:58:21 Error Running script, init error: Syntax error 28-9-2010 18:58:18 Error Running script, init error: Syntax error 28-9-2010 18:58:18 Error Running script, init error: Syntax error 28-9-2010 18:58:17 Error Running script, init error: Syntax error 28-9-2010 18:58:16 Error Running script, init error: Syntax error 28-9-2010 18:58:14 Error Running script, init error: Syntax error 28-9-2010 18:58:13 Error Running script, init error: Syntax error 28-9-2010 18:58:12 Error Running script, init error: Syntax error 28-9-2010 18:58:11 Error Running script, init error: Syntax error 28-9-2010 18:58:07 Error Running script, init error: Syntax error 28-9-2010 18:58:06 Error Running script, init error: Syntax error.
