Share devices with another HS server
    Comments, problems....
    Plug-Ins Enabled:
    I don't see the DisplayValues.asp script??
    Just the pollRemoteServer.txt...
      You are correct. It appears the upload manager does not allow .asp extensions. So I reloaded both scripts with the caveat that the .asp file is now a .asp.txt file. You will need to remove the .txt extension after download for it to work.
      You should just be able to copied that renamed .asp file to your remote server's html directory. Make sure you can open it with a web browser. All it does is loop through all your devices and list them. The .txt file can read these and will create HS devices if any are new/changed. If you delete some remotely-- I don't think it is smart enough to figure that out as of yet. You can always delete all your devices for the remote server and they will automagically reimport.
      Anyways, thanks for pointing that out. The directions in the file should clear up the rest.
      Plug-Ins Enabled:
