What this does:
Iconfifier will watch for the --status change-- of predefined devices. As the device changes
state, this will update the icon to match a defined set of parameters. I left a LOT of wiggle
room in HOW it was defined, which prevented me from initially defining a "good" webpage
based way of defining the icons...that is, the HTML in the definition was messing with
how the webpage displayed the devices (such as using Jon00's .ini editor).
As with all my scripts, I am releasing this as "open" unencrypted. If you need the code, I hope it helps you. You are free to change it in any way. Please stick my name in there somewhere if you do and redistribute.
Discussion located here:
http://forums.homeseer.com/showthread.php?p=950960
