VB Scripts no longer loading
    I just migrated my HomeSeer computer from a dying one to one running Windows Vista. I have the new computer with HomeSeer running error free, but there is one thing that has stopped working--my vb scripts no longer load/run.
    When HS starts, there is no error, and the startup completes successfully. However, none of my Insteon scripts loads.
    Anyone have the answer for this one?
    -Joe
    Do you have dotnet 2.0 installed?
    Mike
      also are all your scripts in the scripts directory? Just in case they ended up being copied to a sub directory by accident
        Also, turn off UAC.
        It is very hard to work with. I spent 1-2 weeks playing with it (Win7). I was not ever able to get it to work properly.
        --Dan
        Tasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
          I did turn off UAC right away, and the scripts are indeed being called.
          However, if I run one of the scripts manually in command prompt, the response is that there is no script engine.
          I'll look into the .NET 2.0 and reinstall if necessary.
            I can't remember but is the Microsoft Scripting engine installed by default on Vista?
            Try this, go to your \Windows\System32 directory with a command prompt and type:
            regsvr32 msscript.ocx
            If it comes back with a message that the registration succeeded, then try starting HomeSeer again and see if it works.
            -Rupp
              I always appreciate the help, but it seems that HomeSeer didn't like the fact that I uninstalled .Net and reinstalled it. Now the web server doesn't seem to work. I'll tackle that one with a reinstall of HomeSeer, I think...
              But on the script issue, after a little more observation, what is happening is that the Insteon_ExtSupport.vb is not being called by the plug-in. All of the vb scripts are in the app_path/Scripts directory. So, it's c:\Program Files\HomeSeer 2\scripts
              HomeSeer launches successfully, but ends up not registering the two external Insteon devices. But, it does launch the startup.txt script. Hmm...
                OK, I have the latest version of HS running again successfully, EXCEPT for some reason, the Insteon plugin isn't loading the Insteon_ExtDevSupport.vb script. As a result, my EZIO device and motion sensor device are not registering with the plug in.
                Anyone?
                Here is the startup:
                5/24/2011 9:54:23 PM - Startup -
                5/24/2011 9:54:23 PM - Startup - ************************************************************ ********************
                5/24/2011 9:54:23 PM - Startup - HomeSeer version 2.5.0.20 Starting Now (Standard Build)
                5/24/2011 9:54:23 PM - Startup - Using system's regional settings
                5/24/2011 9:54:23 PM - Startup - Creating Class Objects...
                5/24/2011 9:54:23 PM - Startup - COM port classes started.
                5/24/2011 9:54:23 PM - Startup - Application interface class started.
                5/24/2011 9:54:23 PM - Startup - Web server class started.
                5/24/2011 9:54:23 PM - Startup - E-Mail SEND class started.
                5/24/2011 9:54:23 PM - Startup - E-Mail RECEIVE class started.
                5/24/2011 9:54:23 PM - Startup - Z-Wave class started.
                5/24/2011 9:54:23 PM - Startup - Plug-In Interface class started.
                5/24/2011 9:54:23 PM - Startup - Speech recognition class started.
                5/24/2011 9:54:23 PM - Startup - HSPhone dialer class started.
                5/24/2011 9:54:23 PM - Startup - Loading Settings
                5/24/2011 9:54:23 PM - Startup - Settings Loaded.
                5/24/2011 9:54:23 PM - Startup - Current sunrise/sunset values calculated.
                5/24/2011 9:54:23 PM - Startup - HSPhone external interface class started.
                5/24/2011 9:54:23 PM - Startup - Local voice recognition class started.
                5/24/2011 9:54:23 PM - Startup - Database SAVE process started.
                5/24/2011 9:54:23 PM - Startup - Loading configuration file ...
                5/24/2011 9:54:23 PM - System - Loading device types file...
                5/24/2011 9:54:23 PM - Database - Opening (Mode=Read) up HomeSeer database: C:\Program Files\HomeSeer 2\Config\HomeSeer DB JC.mdb
                5/24/2011 9:54:23 PM - Database - Loading Devices...
                5/24/2011 9:54:23 PM - Load Config - 87 total devices loaded.
                5/24/2011 9:54:23 PM - Load Config - Checking device type settings for all devices...
                5/24/2011 9:54:23 PM - Load Config - Finished checking device type settings.
                5/24/2011 9:54:23 PM - Load Config - Loading Events...
                5/24/2011 9:54:24 PM - Load Config - 88 total events loaded.
                5/24/2011 9:54:24 PM - Database - HomeSeer configuration database C:\Program Files\HomeSeer 2\Config\HomeSeer DB JC.mdb has been closed.
                5/24/2011 9:54:24 PM - Startup - HomeSeer version is: 2.5.0.20
                5/24/2011 9:54:24 PM - Startup - Starting remoting (Remote client connection monitor)
                5/24/2011 9:54:24 PM - Startup - Creating Speaker Client Interface Object...
                5/24/2011 9:54:24 PM - Startup - Initializing phone interface...
                5/24/2011 9:54:24 PM - HSPhone - HomeSeer Phone Web Interface initializing.
                5/24/2011 9:54:24 PM - Startup - Checking for pending updates to be installed...
                5/24/2011 9:54:24 PM - Startup - Restoring Device Status...
                5/24/2011 9:54:24 PM - Startup - Checking for available plug-ins
                5/24/2011 9:54:24 PM - Plug-In - Found plug-in: ActiveBackup Plugin, version: 2.0.0.26
                5/24/2011 9:54:24 PM - Plug-In - Found plug-in: Insteon, version: 1.4.2.0
                5/24/2011 9:54:24 PM - Plug-In - Found plug-in: Media Player, version: 2.0.0.12
                5/24/2011 9:54:24 PM - Startup - Initializing Plug-Ins
                5/24/2011 9:54:24 PM - Plug-In - Initializing Plug-in: Insteon on COM port 11
                5/24/2011 9:54:25 PM - Insteon - PLM contacted on COM11 with an Insteon address of 0C.AE.09 and firmware version 63
                5/24/2011 9:54:25 PM - Plug-In - Finished initializing plug-in Insteon
                5/24/2011 9:54:25 PM - Plug-In - Initializing Plug-in: ActiveBackup Plugin
                5/24/2011 9:54:25 PM - ActiveBackup Info - by TheMax74
                5/24/2011 9:54:25 PM - ActiveBackup Info - Found Global device on ]1
                5/24/2011 9:54:25 PM - Plug-In - Finished initializing plug-in ActiveBackup Plugin
                5/24/2011 9:54:25 PM - Plug-In - Initializing X10 Plug-in: Insteon On COM Port 11
                5/24/2011 9:54:25 PM - Plug-In - Initializing Plug-in: Insteon
                5/24/2011 9:54:25 PM - Plug-In - Finished initializing X10 interface Insteon
                5/24/2011 9:54:25 PM - Plug-In - Finished initializing infrared interface
                5/24/2011 9:54:25 PM - Web Server - Local IP address (subnet) is: 192.168.1.66 (255.255.255.0)
                5/24/2011 9:54:25 PM - Web Server - Web Server started on port 80
                5/24/2011 9:54:25 PM - Startup - Creating ASP.NET application host...
                5/24/2011 9:54:27 PM - Startup - ASP.NET application host created
                5/24/2011 9:54:27 PM - Startup - Start automation engine...
                5/24/2011 9:54:27 PM - Startup - This version of HomeSeer is registered.
                5/24/2011 9:54:27 PM - Startup - Initializing Speaker Client Interface
                5/24/2011 9:54:27 PM - Speech - Listening for remote speaker connections on port 8742
                5/24/2011 9:54:27 PM - Startup - Starting Event Scheduler...
                5/24/2011 9:54:27 PM - Startup - Checking HTTP connection...
                5/24/2011 9:54:27 PM - Web Server - Web Server authorized local login successful from: 127.0.0.1
                5/24/2011 9:54:27 PM - Startup - Updater services starting...
                5/24/2011 9:54:27 PM - Startup - Starting DDNS service...
                5/24/2011 9:54:27 PM - Startup - Running the Startup.txt Script
                5/24/2011 9:54:27 PM - Startup - Scripting is OK
                5/24/2011 9:54:27 PM - Startup - Start up complete.
